FTM S32k144 indepentent PWM channel
lohrsistemas
Dear Team,
How do I configure the module FMT1 channel 4 as a simple PWM, independent channel, 200 Hz, without using Processor Expert?
I'll have to update the duty amount on my main loop.
Does anyone have an example?
Tags (2)
danielmartynek
Please take a look at the attached simple example.
The duty cycle and period of a left-aligned PWM is being continuously updated from the main loop using software triggers.
danielmartynek
bjrajendra
Senior Contributor I
Hi Daniel,
I would like to know about the possibility of modulating on FTM2 & I'd raised few issues on using
SIM->FTMOPT1=SIM_FTMOPT1_FTM3_OUTSEL(0x01); how does this help in modulation and what is its significance?
Similar thing I asked a question in FTM2 Output Modulation.
Kindly suggest to us in this regard.
Raju
lohrsistemas
Hi Daniel,
Thank you very much.
