How to open .abs files
jixiangli
Hello everyone,
            In the CODEWARRIOR programming environment, after the new project is compiled, the.abs file will be generated. What software can be used to open the.abs file? Please make a recommendation. Thank you very much!!!
Hello jixiang li ,
You can try to open it using UltraEdit .
Hope it helps,
TIC
jixiangli
OK,thank you !
