Thank you for your concern Jennie Zhang.But I'm getting not only the scalability issue but also i couldn't create the new project file.Hope i get solution for this.
Thanks in advance!
Dhanushma
Hi Chennam,
I would suggest you remove your .metadata folder of your workspace, then try create new project again.
You may need backup your .metadata before the removal.
Jennie Zhang
I'm using MPC5643L controller
Besides, Please check if this article can help you
Eclipse Editor Scalability | MCU on Eclipse
Jennie Zhang
Could you tell us which MCU are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
