Hi!
I had download the android_O8.1.0_1.3.0_8M_image_8mq.tar from NXP and android_O8.1.0_1.3.0_8M_tools, Now I want to use mfgtools to burn the imx8m evk board, but before the burn in the mfgtools files where to locate the files of android_O8.1.0_1.3.0_8M_image_8mq.tar and which files need to copy to that location?.
Thank you!
Hi Hui,
Here you can copy the Prebuilt-image to the mfgtool location mfgtools/Profiles/Linux/OS Firmware/files/android/evk. Following the 3.3 Flashing board images of Android_Quick_Start_Guide.pdf.
Rita
Download https://www.nxp.com/docs/en/supporting-information/android_O8.1.0_1.3.0_8M_docs.tar.gz - Android_Quick_Start_Guide.pdf
Image file location: MFGTool-Dir/Profiles/Linux/OS Firmware/files/android/evk
Rename and copy image file according to section 3.3 description.
Tony Lee
