call camera startPreview ,the preview frame has about 10dp black border, Could anybody tell haw to do... thx
Hello Running,
You have a bad configuration of your Camera Settings refer to the DTS (device Tree) where the camera it is connected and change the resolution or your camera, or you are using a wrong driver for the camera and the settings from the firmware are incorrect which you need to add a different driver.
Best Regards
TIC Support Team
