CSI/SCI/DMA config
CSI/SCI/DMA config
mynampatikuldee
I am trying to configure and run CSI mode ( SPI/DSI ) & SCI/DMA for MPC5777. I am looking for examples and application notes from NXP. But could not find from NXP site. Can anyone please provide any links or docs?
KK
Tags (2)
davidtosenovjan
I could recommend following appnote, it describes old module version that is however backward compatible, but I think it could helpful anyway:
http://www.nxp.com/assets/documents/data/en/application-notes/AN2867.pdf
Regrading SCI/DMA, I am attaching simple example code. The rest of the files for this example you may use from following:
https://community.nxp.com/docs/DOC-328290
mynampatikuldee
I am sorry. I will rephrase the question. I have already configured SIU_ETPUA, SIU_ETPUB and SIU_EMIOSA/B as desired
in serialized output selection register.
Ex:
ETPUB16, I can see appropriate bit toggling in eTPUB16 channel as well as in DSPIC_SDR0 register.  With appropriate DSCR0, DSCR1 register settings. I expect data frames at output. But unable to see the output.
Are there any other setting's in SIU apart from above mentioned.
KK
mynampatikuldee
Thanks alot. That was quite helpful. I was able to successfully configure DSIPC in CSI mode, DSCR1, DSCR2 to desired and able to see SDR0 register bit toggling when I enable (eTPUB9) channel for DSPI serialization. But unable to see output. Are there any registers in SIU to be configured?
KK
davidtosenovjan
Pay attention to following register group:
davidtosenovjan
