Some DMA problem of the P2020
zhu_haifeng
In recent day, I use the p2020 to communicate with other point just like FPGA and DSP, I use the RapidIO bus via DMA to communicate. when i disconnect the FPGA and i send the data to the disconnect fpga. the DMA report a problem and can not recover. my problem is how to recover the DMA when the DMA abort. the register is mr and sr. datasheet i have read.
Tags (2)
ufedor
It is needed to clear corresponding BCR register.
