Is it available to use the evaluation board OM13098 as is for a commercial product with our own applications?
Sj
Solved! Go to Solution.
Hi SJ,
Glad to hear you like the board enough to want to design it in :smileyhappy:
We generally do not recommend using our boards for OEM products, as they aren't designed for more than desk top / lab use, and management of supplying large volumes to an end customer such as yourself could be difficult. Instead we would refer you to one of our partners, such as Embedded Artists (EA), FDI or Embest Technology who specialize in supplying and supporting OEMs. In this particular case the board is made by Embest, who should be able to supply the boards to you directly. FDI also have an LPC546xx OEM board already and, depending on volume, EA may also be able to offer something.
Hi SJ,
