I think you've got it right for the "Needed" pins, but I have to admit I'm not actually using SMAC (and I'm using an MC13201). The other pins allow you to implement lower power modes under MCU control. RST* allows you to shut the transceiver off and RXTXEN allows you to go to idle mode. ATTN* allows you to wake the transceiver from doze or hibernate mode. Since I have a limited number of pins, I chose just your "Needed" pins, plus RST* and RXTXEN (and gave up doze/hibernate in favor of off/idle) -- we'll see if it works next week! :smileyhappy:
-- Rich
