FTM_CLK use
FTM_CLK use
javierhernande1
K27
FTM_CLKIN0 and FTM_CLKIN1 is to connect a external crystal?
mjbcswitzerland
Specialist V
Hi Javier
These are not crystal oscillator inputs but instead clock inputs that can be selected as alternative clock sources to the FlexTimers.
Mark
uTasker developer and supporter (+5'000 hours experience on +60 Kinetis derivatives in +80 product developments)
Kinetis: http://www.utasker.com/kinetis.html
mjbcswitzerland
Specialist V
Hi Javier
Mark
javierhernande1
Thank you,
I cann't find it in the datasheet.
javierhernande1
Ok,
I have found in K27P169M150SF5RM document. The reference manual.
