I have just bought the NTAG I2C plus Explorer Kit with NFC reader:
OM5569-NT322ER | NTAG I2C plus Explorer Kit + reader|NXP
After installing the reader driver + Ntag I2C demo software, it did work. The locker icon on the upper right corner is black all the time, and there is no responce after cliking the 3 buttons on the software (Orange, Blue, Green).
What could be the problem? Thank you!
Yueming
Hi Kan,
Thank you very much for the reply!
The problem is solved now. It's due the driver issue. The NFC reader needs to install its own driver, too.
After fixing this, everythng works fine now.
Yueming
Hi Yueming,
Which demo did you choose to play with the demo board? NTAG I²C Demo for windows PC? or the Android version? Please kindly clarify.
Thanks for your patience!
Kan
