I've experienced problem playing back mp4 file on iMX6 system. Software build based on VAR-SOM-MX6 - Yocto Rocko 2.4 based on FSL Community BSP rocko with 4.9.11_1.0.0-ga Linux release. Gstreamer version 1.12.2. Video/audio mp4 file created by:
gst-launch-1.0 -v -e imxv4l2videosrc num-buffers=100 device=/dev/video0 ! queue ! imxvpuenc_h264 gop-size=7 bitrate=4000 ! h264parse ! video/x-h264,stream-format=avc ! mp4mux name=mux dts-method=dd ! filesink locatio
n=test1.mp4 alsasrc num-buffers=100 do-timestamp=true ! audio/x-raw, format=S16LE, rate=44100, channels=2 ! queue ! imxmp3audioenc bitrate=96 ! queue ! mux.audio_0
When I run command to play:
gst-launch-1.0 filesrc location=test1.mp4 ! qtdemux ! h264parse ! imxvpudec ! imxeglvivsink
I'm getting error:
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
ERROR:../src/vpu/decoder.c:921:gst_imx_vpu_decoder_decide_allocation: assertion failed: (vpu_decoder->decoder_context != NULL)
Aborted
I've tried to playback the same file, but with gstreamer v1.08:
./gst-launch-1.0 filesrc location=test1.mp4 ! qtdemux ! h264parse ! vpudec ! v4l2sink
and it played back correctly. On PC I also can play this file with audio.
Do you know how to resolve this error (vpu_decoder->decoder_context != NULL) in newer gstreamer.
I've added file with debug output in attachment.
Hi Pavel
one can open issue on gstreamer-imx
https://github.com/Freescale/gstreamer-imx/issues
Alternatively one can try with NXP gstreamer plugins (imx-gst1.0-plugins) described in
sect.7.3 Multimedia use cases attached Linux Guide.
Difference is described on
trac.gateworks.com/wiki/Yocto/gstreamer
I'll repost this issue to https://github.com/Freescale/gstreamer-imx/issues
