Hi Sir,
I foond .mex file for MCIMX6Q-SDB from community page , is there a .mex file available for imx7 SDB ?
https://community.nxp.com/message/976750?commentID=976750#comment-976750
Thanks!
Solved! Go to Solution.
Hi Jimmy,
The .mex is generated after you select to "Create a new configuration for a borad or porcessor" here you can select i.MX7 SDB and .mex will be generated.
You can download the pins tools here:
Pins Tool for i.MX Application Processors|NXP
Carlos
NXP Technical Support
Hi Jimmy,
Carlos
