Can I run linux on Freedom board?
jotero
Does freedom board using the MK22FN512VLH12 support linux?
BlackNight
For running Linux you typically need an MMU, and the K22F does not have this. This is more a microcontroller range processor (ARM Cortex-M4F) and not designed to run a Linux operating system. To run Linux you should consider an ARM Cortex-A processor.
I hope this helps,
Erich
