Good morning
I installed the KDS on a 4K resolution display, and the icons on the tool bar are incredibly reduced, not for confortable using.
Is there a solution to make them bigger?
Thank You
Thank You
It is definitely working...
Hi Pietro,
see Dealing with Eclipse and Very Small Icons on Ultra High Density Displays | MCU on Eclipse
I hope this helps,
Erich
