CAN Recevier issue
CAN Recevier issue
剑明肖
I run the CAN demo (can_model_pnt.mdl) in MBDT toolbox(MBDToolbox\mbdtbx_MPC574xP\mbdtbx_pnt\Examples), it works well. But when I add another CAN_Receive_Data_Trigger(configured the different message id) block into the program, the CAN can not receive messages. Are there anyone met the same issue? Why this happen and how to fix it?
Attach is my simulink program.
mariuslucianand
Hello 剑明 肖,
Thank you for reporting this issue.
I think this is caused by a toolbox bug, so I prepared a fix for this.
Please try replacing the following files with the ones attached, but before that please make a backup for the existing ones.
{Toolbox install dir}\mbdtbx_MPC574xP_2.0\mbdtbx_pnt\src\mbdtbx_pnt\src\c_library  folder flexcan_pnt_library.c file
{Toolbox install dir}\mbdtbx_MPC574xP_2.0\mbdtbx_pnt\mbdtbx_pnt\blocks\can  folder can_pnt_receive_data_trigger.tlc file
Please give us a feedback after you replaced the files.
Marius
mariuslucianand
Hello 剑明 肖,
Marius
