I need to interface the Serial SPI LCD display to custom imx6 board using Linux 3.0.35 kernel.
Here is my LCD display which is using ILI9806E( RGB+3LINE-9bit-SPI-COMMAND) controller.
Could I init LCD display by config CSPI1 and how to do it ?
I don't found any related code in the Linux 3.0..35.
How and where could I add some BSP support for the new LCD display .
Any helps.Documents , codes and so on.
Thanks for your help.
Kind Regards.
Hi Titus
please look on
How to use SPI slave within U-Boot?
Hi, igor
Thanks for your reply.
But I need config ECSPI1 for SPI master, not slave.
And I need initialize LCD display by ECSPI1's output.
I had not found any useful reference document in community for I.MX6.
I found source file ,who's mxcfb_epson_vga.c is similar to my situation in Linux 3.0.35 's drivers.
But I am not clear that the driver as my menitoned suit me well.
Any clue about BSP support and LCD drivers, please!
Kind Regards.
