Dear NXP engineer:
hello,There is no Lauterbach debugger in my hand if I want to decode SPT instructions,view SPT memories, modify memories dump contents,Only use Lauterbach debugger? Can be replaced by other, such as isystem and PE?
PS:I use the processor that is S32R274
I am not sure about this. Maybe iSystem. I do not expect PE support SPT.
Best would be to ask debugger vendors for this.
Peter
Hi,Peter
Glad you answered,But I still have a question,if I want to debug the SPT kernels,e.g.decode SPT instructions,Single-step debug SPT instructions, breakpoint debug SPT instructions and so on.So I have to configure the SPT_CS_MODE_CTRL register,let the command sequencer into the debug state before i debug it?
If i do not do this, no matter what debugger can't debug it?
Hi Tao,
if you use the Lauterbach TRACE32 debugger for SPT, the debugger will modify the SPT registers automatically as required for Single Step etc. No manual modifications required. The SPT debugger is included in our JTAG Debugger for MPC5XXX without additional charges.
Reinhard
I encountered the same problem with you, I do not know if you did not solve it
Not yet resolved, do not know what you have a good way?
