Re: MPC8377 JTAG problem
xiaoluliao
PowerQUICC Processors
Hi:
  @alexander.yakovlev,
  Configuration information has been OK when I test PCI_SYNC_OUT,I found 33.33MHZ。But
JTAG link failure.
Please help me to solve this problem ,thank you!
when I
alexander_yakov
This question is not related to previous Lauterbach-related topic, so I've separated it to another topic.
As far as I can see, your CodeWarrior says "Failed to correctly configure the JTAG chain".
This is very frequent issue, please search this community by using this string "Failed to correctly configure the JTAG chain" as keyword to find a solution.
