KDS Version 3.2.0 unstable under MacOS High Sierra 10.13.1?
robertpoor
Senior Contributor I
I've been using KDS V 3.2.0 for a long time without trouble.  Last night, I upgraded my laptop to MacOS High Sierra 10.13.1.  Now I'm observing KDS crashing.  I haven't narrowed it down to a specific thing, but this recipe sometimes makes it crash:
  • Open a project
  • Modify a file
  • Save the file
  • Build the project
(Boom.  Crashes)
  • Relaunch KDS
  • Build the project
(Works this time)
Have any other MacOS users observed this?
robertpoor
Erich Styger points out that MCUXpresso is replacing KDS, so it's probably not reasonable to expect that KDS will keep up with new OS releases.
Erich also wrote an excellent article on porting from KDS to MCUXpresso:
MCUXpresso IDE: Importing Kinetis Design Studio Projects | MCU on Eclipse
Quote from the article:
I have migrated several projects from KDS to MCUXpresso. This post is about how to easily get KDS projects ported and running in MCUXpresso IDE.
So I'll accept that as the proper solution.  I can see I'll be busy for the next few hours...
robertpoor
tamermash
That's unfortunate!!! MCUXpresso crashes in the same manner as KDS, so will you guys at least release a fix for that???
BlackNight
The MCUXpresso IDE is going to address this at least in the next 10.2 (date tbd). Until then, the patch discussed in https://community.nxp.com/thread/461733  should apply for the MCUXpresso IDE 10.1.
tamermash
Won't be able to move to that anytime soon! Thanks for nothing NXP!!!!!
tamermash
Erich, can you please point me to the fix that you used to patch MCUXpresso so I can try to apply it myself to KDS?
BlackNight
There is a patch described in MCUXpresso 10.0.2 Crash in macOS High Sierra (10.13) .
It points to an Eclipse bug report (527171 – [10.13] Selecting more than a few lines and deleting them causes a hard crash in Mac OS Hig... ).
Jeff Williams posted a jar file (https://community.nxp.com/thread/461733#comment-964056 ) which seems to fix the issue in Eclipse Neon: It looks from the thread above that you tried that and it did not work?
The other route is build a 'KDS based on Eclispe Oxygen. To my understanding that Mac issue is fixed in the latest Oxygen.
the following tutorial
Breathing with Oxygen: DIY ARM Cortex-M C/C++ IDE and Toolchain with Eclipse Oxygen | MCU on Eclipse
describes  how to build what is in KDS, but in DIY way (sorry: Windows again, but things should be very similar for Mac). What that article does not cover is Processor Expert. The following article describes (Windows used in the tutorial) how to install it into Neon (I have used the same with Oxygen too):
MCUXpresso IDE: Installing Processor Expert into Eclipse Neon | MCU on Eclipse
I hope this helps,
Erich
tamermash
One more question, I'm not familiar with how Eclipse is built and haven't worked with java for a long time, but I was thinking if I can download the sources for that swt file and build it, that might work. Is it possible to only build that one file? If so, do you know where I can get the source? Do you guys have the sources for KDS available so I can patch it myself?
BlackNight
Building Eclipse will not be that simple. And I have not checked what exactly has been changed in that Jar file.
The KDS sources are availble from NXP.com (Kinetis® Design Studio Integrated Development Environment (IDE)|NXP ) in the downloads section. The zip file (I had used the one for V2.0.0) includes the modified parts, but not the 'plain vanilla' parts like the Eclipse sources itself. The Eclipse Luna sources would be availble from the Eclipse project page (Luna | projects.eclipse.org ).
I hope this helps,
Erich
tamermash
Thank you
tamermash
Great, I will try that. Thank you Erich
tamermash
I know Erich has a manual patch further up in this thread, but that really needs to be packaged in a new release if you guy want to give good support here!
tamermash
I would like to also note that it will take someone like Erich very little time to apply the patch to KDS and make everyone happy!
netstv73
Hey NXP,
We don't support Mac OS High Sierra excuse doesn't work anymore.  Unpleasant to downgrade I've tried it... it is horrible and I wasted two days on this.
The Eclipse community is working on fixing this, can you guys PLEASE fix this.  It makes working with KDS impossible.  I restart at least 10 times a day if not more.
Thank you.
tamermash
I have the same problem and agreed, this must be fixed. Below is my crash report
Process: kinetis-design-studio [19363]
Path: /Applications/KDS_v3.2.app/Contents/eclipse/kinetis-design-studio
Identifier: com.freescale.kds
Version: 3.2.0 (3.2.0)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: kinetis-design-studio [19363]
User ID: 501
Date/Time: 2018-01-09 13:49:55.820 -0800
OS Version: Mac OS X 10.13.2 (17C88)
Report Version: 12
Anonymous UUID: 41B0B9F6-492A-0C48-CFAB-F67453817411
Sleep/Wake UUID: 7B49ED5B-DD46-488C-8B3A-8029CD3E3E7E
Time Awake Since Boot: 61000 seconds
Time Since Wake: 16000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000008
Exception Note: EXC_CORPSE_NOTIFY
VM Regions Near 0x8:
__TEXT 0000000100000000-0000000100004000 [ 16K] r-x/rwx SM=COW |  [/Applications/KDS_v3.2.app/Contents/eclipse/kinetis-design-studio]
Application Specific Information:
Assertion failed: (backing->lock_access > 0), function CGSBackingStoreUnlockReader, file /BuildRoot/Library/Caches/com.apple.xbs/Sources/SkyLight/SkyLight-312.23.4/SkyLight/Services/Windows/CGSBackingStore.c, line 360.
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff50ba1e3e __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff50ce0150 pthread_kill + 333
2 libsystem_c.dylib 0x00007fff50afe312 abort + 127
3 libsystem_c.dylib 0x00007fff50ac6368 __assert_rtn + 320
4 com.apple.SkyLight 0x00007fff4aa9cb92 SLSUnlockWindowBackingStore + 124
5 com.apple.CoreGraphics 0x00007fff29654519 CGSImageDataLockDevice + 482
6 com.apple.CoreGraphics 0x00007fff29704d5b ripc_DrawWindowContents + 1115
7 com.apple.CoreGraphics 0x00007fff2968a1cc CGContextDelegateDrawWindowContents + 59
8 com.apple.SkyLight 0x00007fff4abd9af8 SLContextCopyWindowContentsToRect + 178
9 libswt-pi-cocoa-4430.jnilib 0x000000012581414b Java_org_eclipse_swt_internal_cocoa_OS_CGContextCopyWindowContentsToRect + 345
10 ??? 0x0000000107fbe9f4 0 + 4428917236
11 ??? 0x0000000107faf2bd 0 + 4428853949
12 ??? 0x0000000107fa77a7 0 + 4428822439
13 libjvm.dylib 0x00000001072ee70a JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 1710
14 libjvm.dylib 0x00000001074d3c0c Reflection::invoke(instanceKlassHandle, methodHandle, Handle, bool, objArrayHandle, BasicType, objArrayHandle, bool, Thread*) + 3602
15 libjvm.dylib 0x00000001074d4140 Reflection::invoke_method(oopDesc*, Handle, objArrayHandle, Thread*) + 364
16 libjvm.dylib 0x0000000107346b0c JVM_InvokeMethod + 358
17 ??? 0x000000010926742d 0 + 4448482349
18 ??? 0x000000010926e9d4 0 + 4448512468
Thread 1:
0 libsystem_kernel.dylib 0x00007fff50ba2562 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff50cdd26f _pthread_wqthread + 1552
2 libsystem_pthread.dylib 0x00007fff50cdcc4d start_wqthread + 13
Thread 2:
Thread 3:
0 libsystem_kernel.dylib 0x00007fff50ba1cee __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff50cde662 _pthread_cond_wait + 732
2 libjvm.dylib 0x000000010748788a os::PlatformEvent::park() + 192
3 libjvm.dylib 0x000000010746495e ParkCommon(ParkEvent*, long) + 42
4 libjvm.dylib 0x0000000107465234 Monitor::IWait(Thread*, long) + 168
5 libjvm.dylib 0x000000010746549d Monitor::wait(bool, long, bool) + 375
6 libjvm.dylib 0x00000001072761be GCTaskManager::get_task(unsigned int) + 56
7 libjvm.dylib 0x000000010727728b GCTaskThread::run() + 349
8 libjvm.dylib 0x000000010748baee java_start(Thread*) + 246
9 libsystem_pthread.dylib 0x00007fff50cdd6c1 _pthread_body + 340
10 libsystem_pthread.dylib 0x00007fff50cdd56d _pthread_start + 377
11 libsystem_pthread.dylib 0x00007fff50cdcc5d thread_start + 13
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
2 libjvm.dylib 0x0000000107488774 os::PlatformEvent::park(long) + 404
3 libjvm.dylib 0x0000000107465234 Monitor::IWait(Thread*, long) + 168
4 libjvm.dylib 0x000000010746549d Monitor::wait(bool, long, bool) + 375
5 libjvm.dylib 0x00000001075b83b6 VMThread::loop() + 444
6 libjvm.dylib 0x00000001075b7e41 VMThread::run() + 121
7 libjvm.dylib 0x000000010748baee java_start(Thread*) + 246
8 libsystem_pthread.dylib 0x00007fff50cdd6c1 _pthread_body + 340
9 libsystem_pthread.dylib 0x00007fff50cdd56d _pthread_start + 377
10 libsystem_pthread.dylib 0x00007fff50cdcc5d thread_start + 13
Thread 12:: Java: Reference Handler
3 libjvm.dylib 0x000000010747f3ba ObjectMonitor::wait(long, bool, Thread*) + 748
4 libjvm.dylib 0x0000000107538a00 ObjectSynchronizer::wait(Handle, long, Thread*) + 202
5 libjvm.dylib 0x00000001073501c3 JVM_MonitorWait + 156
6 ??? 0x0000000108fa7aa8 0 + 4445600424
7 ??? 0x0000000108194cec 0 + 4430843116
Thread 13:: Java: Finalizer
7 ??? 0x00000001081e5e24 0 + 4431175204
Thread 14:: Java: Signal Dispatcher
0 libsystem_kernel.dylib 0x00007fff50b987fe semaphore_wait_trap + 10
1 libjvm.dylib 0x0000000107489ddc check_pending_signals(bool) + 128
2 libjvm.dylib 0x0000000107486915 signal_thread_entry(JavaThread*, Thread*) + 57
3 libjvm.dylib 0x000000010756c0b3 JavaThread::thread_main_inner() + 155
4 libjvm.dylib 0x000000010756d7a0 JavaThread::run() + 450
5 libjvm.dylib 0x000000010748baee java_start(Thread*) + 246
6 libsystem_pthread.dylib 0x00007fff50cdd6c1 _pthread_body + 340
7 libsystem_pthread.dylib 0x00007fff50cdd56d _pthread_start + 377
8 libsystem_pthread.dylib 0x00007fff50cdcc5d thread_start + 13
Thread 15:: Java: C2 CompilerThread0
4 libjvm.dylib 0x0000000107465404 Monitor::wait(bool, long, bool) + 222
5 libjvm.dylib 0x00000001071b93c0 CompileQueue::get() + 122
6 libjvm.dylib 0x00000001071b95e2 CompileBroker::compiler_thread_loop() + 376
7 libjvm.dylib 0x000000010756c0b3 JavaThread::thread_main_inner() + 155
8 libjvm.dylib 0x000000010756d7a0 JavaThread::run() + 450
9 libjvm.dylib 0x000000010748baee java_start(Thread*) + 246
10 libsystem_pthread.dylib 0x00007fff50cdd6c1 _pthread_body + 340
11 libsystem_pthread.dylib 0x00007fff50cdd56d _pthread_start + 377
12 libsystem_pthread.dylib 0x00007fff50cdcc5d thread_start + 13
Thread 16:: Java: C2 CompilerThread1
Thread 17:: Java: C2 CompilerThread2
Thread 18:: Java: C1 CompilerThread3
Thread 19:: Java: Service Thread
6 libjvm.dylib 0x00000001074e38dc ServiceThread::service_thread_entry(JavaThread*, Thread*) + 132
Thread 20:
5 libjvm.dylib 0x000000010756c590 WatcherThread::sleep() const + 126
6 libjvm.dylib 0x000000010756d415 WatcherThread::run() + 243
Thread 21:
Thread 22:
Thread 23:: Java: Active Thread: Equinox Container: a0eb1af3-86f5-0017-18ea
2 libjvm.dylib 0x0000000107488552 Parker::park(bool, long) + 512
3 libjvm.dylib 0x000000010758289b Unsafe_Park + 126
4 ??? 0x0000000107fbe9f4 0 + 4428917236
5 ??? 0x0000000107faf2bd 0 + 4428853949
6 ??? 0x0000000107faf2bd 0 + 4428853949
7 ??? 0x0000000107faee15 0 + 4428852757
8 ??? 0x0000000107faf040 0 + 4428853312
9 ??? 0x0000000107faf114 0 + 4428853524
10 ??? 0x0000000107faf040 0 + 4428853312
12 ??? 0x0000000107faf302 0 + 4428854018
13 ??? 0x0000000107fa77a7 0 + 4428822439
14 libjvm.dylib 0x00000001072ee70a JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 1710
15 libjvm.dylib 0x00000001072eeeae JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 356
16 libjvm.dylib 0x00000001072ef05a JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 74
17 libjvm.dylib 0x00000001073497b1 thread_entry(JavaThread*, Thread*) + 124
18 libjvm.dylib 0x000000010756c0b3 JavaThread::thread_main_inner() + 155
19 libjvm.dylib 0x000000010756d7a0 JavaThread::run() + 450
20 libjvm.dylib 0x000000010748baee java_start(Thread*) + 246
21 libsystem_pthread.dylib 0x00007fff50cdd6c1 _pthread_body + 340
22 libsystem_pthread.dylib 0x00007fff50cdd56d _pthread_start + 377
23 libsystem_pthread.dylib 0x00007fff50cdcc5d thread_start + 13
Thread 24:: Java: Framework Event Dispatcher: Equinox Container: a0eb1af3-8
7 ??? 0x0000000108d18584 0 + 4442916228
8 ??? 0x0000000107fa77a7 0 + 4428822439
9 libjvm.dylib 0x00000001072ee70a JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 1710
10 libjvm.dylib 0x00000001072eeeae JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 356
11 libjvm.dylib 0x00000001072ef05a JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 74
12 libjvm.dylib 0x00000001073497b1 thread_entry(JavaThread*, Thread*) + 124
13 libjvm.dylib 0x000000010756c0b3 JavaThread::thread_main_inner() + 155
14 libjvm.dylib 0x000000010756d7a0 JavaThread::run() + 450
15 libjvm.dylib 0x000000010748baee java_start(Thread*) + 246
16 libsystem_pthread.dylib 0x00007fff50cdd6c1 _pthread_body + 340
17 libsystem_pthread.dylib 0x00007fff50cdd56d _pthread_start + 377
18 libsystem_pthread.dylib 0x00007fff50cdcc5d thread_start + 13
Thread 25:: Java: Start Level: Equinox Container: a0eb1af3-86f5-0017-18ea-8
6 ??? 0x0000000107fbe9f4 0 + 4428917236
7 ??? 0x0000000107faf2bd 0 + 4428853949
8 ??? 0x0000000107faf2bd 0 + 4428853949
9 ??? 0x0000000107faf040 0 + 4428853312
10 ??? 0x0000000107fa77a7 0 + 4428822439
11 libjvm.dylib 0x00000001072ee70a JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 1710
12 libjvm.dylib 0x00000001072eeeae JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 356
13 libjvm.dylib 0x00000001072ef05a JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 74
14 libjvm.dylib 0x00000001073497b1 thread_entry(JavaThread*, Thread*) + 124
15 libjvm.dylib 0x000000010756c0b3 JavaThread::thread_main_inner() + 155
16 libjvm.dylib 0x000000010756d7a0 JavaThread::run() + 450
17 libjvm.dylib 0x000000010748baee java_start(Thread*) + 246
18 libsystem_pthread.dylib 0x00007fff50cdd6c1 _pthread_body + 340
19 libsystem_pthread.dylib 0x00007fff50cdd56d _pthread_start + 377
20 libsystem_pthread.dylib 0x00007fff50cdcc5d thread_start + 13
Thread 26:: Java: [Timer] - Main Queue Handler
3 libjvm.dylib 0x000000010747f3cb ObjectMonitor::wait(long, bool, Thread*) + 765
8 ??? 0x0000000107faf302 0 + 4428854018
9 ??? 0x0000000107fa77a7 0 + 4428822439
10 libjvm.dylib 0x00000001072ee70a JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 1710
11 libjvm.dylib 0x00000001072eeeae JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 356
12 libjvm.dylib 0x00000001072ef05a JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 74
13 libjvm.dylib 0x00000001073497b1 thread_entry(JavaThread*, Thread*) + 124
14 libjvm.dylib 0x000000010756c0b3 JavaThread::thread_main_inner() + 155
15 libjvm.dylib 0x000000010756d7a0 JavaThread::run() + 450
16 libjvm.dylib 0x000000010748baee java_start(Thread*) + 246
17 libsystem_pthread.dylib 0x00007fff50cdd6c1 _pthread_body + 340
18 libsystem_pthread.dylib 0x00007fff50cdd56d _pthread_start + 377
19 libsystem_pthread.dylib 0x00007fff50cdcc5d thread_start + 13
Thread 27:: Java: Worker-JM
Thread 28:: Java: EMF Reference Cleaner
Thread 29:: Java: Worker-0
7 ??? 0x0000000109443cf4 0 + 4450434292
Thread 30:: Java: Worker-1
Thread 31:
Thread 32:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff50b987c2 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff50b97cdc mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff291ff355 __CFRunLoopServiceMachPort + 341
3 com.apple.CoreFoundation 0x00007fff291fe6a7 __CFRunLoopRun + 1783
4 com.apple.CoreFoundation 0x00007fff291fdd23 CFRunLoopRunSpecific + 483
5 com.apple.AppKit 0x00007fff2691e3c8 _NSEventThread + 184
Thread 33:: Java: Worker-2
Thread 34:: Java: Bundle File Closer
Thread 35:: Java: Processor Expert events
Thread 36:: Java: Worker-3
Thread 37:: Java: Thread-5
2 libjvm.dylib 0x0000000107488541 Parker::park(bool, long) + 495
7 ??? 0x0000000107faf302 0 + 4428854018
10 ??? 0x0000000107faf114 0 + 4428853524
11 ??? 0x0000000107fa77a7 0 + 4428822439
12 libjvm.dylib 0x00000001072ee70a JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 1710
13 libjvm.dylib 0x00000001072eeeae JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 356
14 libjvm.dylib 0x00000001072ef05a JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 74
15 libjvm.dylib 0x00000001073497b1 thread_entry(JavaThread*, Thread*) + 124
16 libjvm.dylib 0x000000010756c0b3 JavaThread::thread_main_inner() + 155
17 libjvm.dylib 0x000000010756d7a0 JavaThread::run() + 450
18 libjvm.dylib 0x000000010748baee java_start(Thread*) + 246
19 libsystem_pthread.dylib 0x00007fff50cdd6c1 _pthread_body + 340
20 libsystem_pthread.dylib 0x00007fff50cdd56d _pthread_start + 377
21 libsystem_pthread.dylib 0x00007fff50cdcc5d thread_start + 13
Thread 38:: Java: Worker-4
Thread 39:: Java: Thread-7
Thread 40:: Java: EventAdmin Async Event Dispatcher Thread
Thread 41:: Java: Worker-5
Thread 42:: Java: Worker-6
9 ??? 0x0000000107faed00 0 + 4428852480
11 ??? 0x0000000107faf040 0 + 4428853312
12 ??? 0x0000000107faf040 0 + 4428853312
13 ??? 0x0000000107faf040 0 + 4428853312
14 ??? 0x0000000107faf040 0 + 4428853312
15 ??? 0x0000000107faf040 0 + 4428853312
16 ??? 0x0000000107faf114 0 + 4428853524
17 ??? 0x0000000107faf040 0 + 4428853312
18 ??? 0x0000000107faf2bd 0 + 4428853949
19 ??? 0x0000000107faf040 0 + 4428853312
20 ??? 0x0000000107fa77a7 0 + 4428822439
21 libjvm.dylib 0x00000001072ee70a JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 1710
22 libjvm.dylib 0x00000001072eeeae JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 356
23 libjvm.dylib 0x00000001072ef05a JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 74
24 libjvm.dylib 0x00000001073497b1 thread_entry(JavaThread*, Thread*) + 124
25 libjvm.dylib 0x000000010756c0b3 JavaThread::thread_main_inner() + 155
26 libjvm.dylib 0x000000010756d7a0 JavaThread::run() + 450
27 libjvm.dylib 0x000000010748baee java_start(Thread*) + 246
28 libsystem_pthread.dylib 0x00007fff50cdd6c1 _pthread_body + 340
29 libsystem_pthread.dylib 0x00007fff50cdd56d _pthread_start + 377
30 libsystem_pthread.dylib 0x00007fff50cdcc5d thread_start + 13
Thread 43:: Java: Worker-7
Thread 44:: Java: Worker-8
Thread 45:: Java: org.eclipse.cdt.internal.ui.text.CReconciler
Thread 46:: Java: org.eclipse.cdt.internal.ui.text.CReconciler
Thread 47:
Thread 48:
Thread 49:: CVDisplayLink
1 libsystem_pthread.dylib 0x00007fff50cde69b _pthread_cond_wait + 789
2 com.apple.CoreVideo 0x00007fff2adba367 CVDisplayLink::waitUntil(unsigned long long) + 237
3 com.apple.CoreVideo 0x00007fff2adb9918 CVDisplayLink::runIOThread() + 500
4 libsystem_pthread.dylib 0x00007fff50cdd6c1 _pthread_body + 340
5 libsystem_pthread.dylib 0x00007fff50cdd56d _pthread_start + 377
6 libsystem_pthread.dylib 0x00007fff50cdcc5d thread_start + 13
Thread 50:
Thread 51:: Java: Worker-9
Thread 52:: Java: Worker-10
Thread 53:: Java: Worker-11
Thread 54:: Java: Worker-12
Thread 55:: Java: Worker-13
Thread 56:: Java: [ThreadPool Manager] - Idle Thread
Thread 57:: Java: process reaper
0 libsystem_kernel.dylib 0x00007fff50ba2502 __wait4 + 10
1 libjava.dylib 0x0000000103a09195 Java_java_lang_UNIXProcess_waitForProcessExit + 29
2 ??? 0x0000000107fbe9f4 0 + 4428917236
3 ??? 0x0000000107faed00 0 + 4428852480
4 ??? 0x0000000107faf2bd 0 + 4428853949
5 ??? 0x0000000107faf302 0 + 4428854018
Thread 58:: Java: ThreadStreamReader: 1
0 libsystem_kernel.dylib 0x00007fff50ba341a read + 10
1 libjava.dylib 0x0000000103a0c6dc handleRead + 34
2 libjava.dylib 0x0000000103a0c386 readBytes + 395
3 ??? 0x00000001086771c2 0 + 4435964354
4 ??? 0x0000000108e47714 0 + 4444157716
Thread 59:: Java: ThreadStreamReader: 2
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x00007fff89b66340 rcx: 0x00007ffeefbebe38 rdx: 0x0000000000000000
rdi: 0x0000000000000307 rsi: 0x0000000000000006 rbp: 0x00007ffeefbebe70 rsp: 0x00007ffeefbebe38
r8: 0x0000000000000000 r9: 0x0000000000000000 r10: 0x0000000000000000 r11: 0x0000000000000206
r12: 0x0000000000000307 r13: 0x0000000122c76000 r14: 0x0000000000000006 r15: 0x000000000000002d
rip: 0x00007fff50ba1e3e rfl: 0x0000000000000206 cr2: 0x00007fff89b44148
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x100000000 - 0x100003fff +kinetis-design-studio (???) <B1199D53-435A-DF2C-8BF5-F2FEAD2D1FA2> /Applications/KDS_v3.2.app/Contents/eclipse/kinetis-design-studio
0x1000b7000 - 0x1000c0fff +eclipse_1607.so (???) <F98649B9-E3DF-A09F-77A9-349AEAF51668> /Applications/KDS_v3.2.app/Contents/eclipse/plugins/org.eclipse.equinox.launcher.cocoa.macosx.x86_64_1.1.200.v20150204-1316/eclipse_1607.so
0x1003ba000 - 0x1003c4fff +libjli.dylib (1) <232C2B05-0A99-33C9-963A-EC5EEE86D2B1> /Library/Java/JavaVirtualMachines/jdk1.8.0_144.jdk/Contents/Home/jre/lib/jli/libjli.dylib
0x1003ca000 - 0x1003d2ff7 +libverify.dylib (1) <4FAB6AF6-B777-3F47-B787-B9F50E09399A> /Library/Java/JavaVirtualMachines/jdk1.8.0_144.jdk/Contents/Home/jre/lib/libverify.dylib
0x1003e0000 - 0x1003e5fff +libzip.dylib (1) <42563F81-9DD6-3EE5-B220-158F57992BC7> /Library/Java/JavaVirtualMachines/jdk1.8.0_144.jdk/Contents/Home/jre/lib/libzip.dylib
0x103a00000 - 0x103a24fe7 +libjava.dylib (1) <DEB74788-A529-3B1D-B681-E01575FA3FD3> /Library/Java/JavaVirtualMachines/jdk1.8.0_144.jdk/Contents/Home/jre/lib/libjava.dylib
0x103aef000 - 0x103b3998f dyld (519.2.2) <6695F30B-4E88-3C0B-9867-7D738C44A3E6> /usr/lib/dyld
0x107000000 - 0x10780efff +libjvm.dylib (1) <CE37116A-917C-3055-A870-5C10655FA2C1> /Library/Java/JavaVirtualMachines/jdk1.8.0_144.jdk/Contents/Home/jre/lib/server/libjvm.dylib
0x123e4d000 - 0x123e6aff7 +libsunec.dylib (1) <AB095BDD-6F23-32FF-A944-E9E68DF9CC71> /Library/Java/JavaVirtualMachines/jdk1.8.0_144.jdk/Contents/Home/jre/lib/libsunec.dylib
0x1257c3000 - 0x1257fcfff +libswt-cocoa-4430.jnilib (???) <BFDF4C6B-E2EC-1B0E-CEFA-D970BFE6A3EC> /Applications/KDS_v3.2.app/Contents/eclipse/configuration/org.eclipse.osgi/462/0/.cp/libswt-cocoa-4430.jnilib
0x125810000 - 0x125836fff +libswt-pi-cocoa-4430.jnilib (???) <EE434043-CA6B-5EDF-3D79-BF08FC68B7C6> /Applications/KDS_v3.2.app/Contents/eclipse/configuration/org.eclipse.osgi/462/0/.cp/libswt-pi-cocoa-4430.jnilib
0x12589d000 - 0x12589efff +libunixfile_1_0_0.jnilib (???) /Applications/KDS_v3.2.app/Contents/eclipse/configuration/org.eclipse.osgi/176/0/.cp/os/macosx/libunixfile_1_0_0.jnilib
0x125a00000 - 0x125ac3ffb com.apple.AMDRadeonX4000GLDriver (1.60.24 - 1.6.0) <5DBE8164-D0C6-3E6D-B723-9EFF799540C6> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x125b13000 - 0x125c48fff com.apple.AMDMTLBronzeDriver (1.60.24 - 1.6.0) <6B1B8B5B-F714-3454-B581-41315D5F8741> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x125fe4000 - 0x125ff3ff7 +libnet.dylib (1) <CB2CDDEA-1646-300F-B34F-6BF2048E8D62> /Library/Java/JavaVirtualMachines/jdk1.8.0_144.jdk/Contents/Home/jre/lib/libnet.dylib
0x126800000 - 0x126d46fff com.apple.driver.AppleIntelHD5000GraphicsGLDriver (10.30.12 - 10.3.0) <CD42232B-7638-32B2-8725-D04CE32CD37D> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver
0x1272c8000 - 0x1272d0fff +libnio.dylib (1) <62D68962-D280-3973-990E-48251E8A4EF6> /Library/Java/JavaVirtualMachines/jdk1.8.0_144.jdk/Contents/Home/jre/lib/libnio.dylib
0x7fff218a1000 - 0x7fff21befff7 com.apple.RawCamera.bundle (8.02.0 - 1017.2.2) <C799730B-C745-3775-BCE7-C67B8BD97FDB> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff21e37000 - 0x7fff22661ff7 ATIRadeonX4000SCLib.dylib (1.60.24) <4BC835B1-A3BF-34BD-9D73-0537AC70CAF4> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x7fff23134000 - 0x7fff231b7ff7 com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (10.30.12 - 10.3.0) <E44B1F7B-5243-3FC2-A803-4D3FB0C53A0D> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver
0x7fff25760000 - 0x7fff25760fff com.apple.Accelerate (1.11 - Accelerate 1.11) <5AA750F5-D633-32BA-B7F3-4F651FB1761E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff25761000 - 0x7fff25777fe3 libCGInterfaces.dylib (417) <27E09D39-51B5-3297-BE33-0DB1736B833A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff25778000 - 0x7fff25c76fc3 com.apple.vImage (8.1 - ???) <310976EE-E12D-39D7-8F58-6EE924E08576> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff25c77000 - 0x7fff25dd1fcb libBLAS.dylib (1211.30.1) <0DB0D952-BCF4-3479-BA2F-785FB1A57479> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff25dd2000 - 0x7fff25e00fef libBNNS.dylib (37) <49EB4DBA-877C-3D41-90A2-C3D982C72A54> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff25e01000 - 0x7fff261c1ff7 libLAPACK.dylib (1211.30.1) <2D4E4446-6B63-350C-BD68-A1B8FBE99539> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff261c2000 - 0x7fff261d7ff7 libLinearAlgebra.dylib (1211.30.1) <6C68F41D-1398-3AFE-BE72-C0ECA1B24BDC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff261d8000 - 0x7fff261ddff3 libQuadrature.dylib (3) <3D6BF66A-55B2-3692-BAC7-DEB0C676ED29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff261de000 - 0x7fff2623cfff libSparse.dylib (79.1.1) <7AD0F8A8-FD36-36FE-B83D-58648EBD0027> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff2623d000 - 0x7fff26250fff libSparseBLAS.dylib (1211.30.1) <42506F6F-0F38-322E-9903-C1DB66E4DA05> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff26251000 - 0x7fff263fdfc3 libvDSP.dylib (622.20.8) <6FFCA52B-7D60-326A-ADF2-601F39A8685A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff263fe000 - 0x7fff264aefef libvMisc.dylib (622.20.8) <54F90047-879F-3260-8604-6E453149B49E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff264af000 - 0x7fff264affff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <8A96A8ED-7B88-3D17-8D17-41D224E0EC90> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff2679f000 - 0x7fff275fcfff com.apple.AppKit (6.9 - 1561.20.106) <7A71ACCF-2DF5-3557-BB22-3A9FC9F71CCF> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff2764e000 - 0x7fff2764efff com.apple.ApplicationServices (48 - 50) <7627DBD6-497B-3AB7-9B63-F0532EDF09B8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff2764f000 - 0x7fff276b5fff com.apple.ApplicationServices.ATS (377 - 445) <CDF5F6D7-4E7D-3D28-9FBA-1B53AD9FA8F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff2774e000 - 0x7fff27870fff libFontParser.dylib (222.1.2) <11BD5EEF-AF18-33FB-B114-DD611932E822> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff27871000 - 0x7fff278bbff7 libFontRegistry.dylib (221) <A22F82C0-B4FE-3DB5-B968-79B28257DF2F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff27960000 - 0x7fff27993ff7 libTrueTypeScaler.dylib (222.1.2) <33C245B4-E1AD-3C89-B735-5A5610E547C8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff279fd000 - 0x7fff27a01ff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <42C25E85-1CF3-3DEC-A434-BE69F68F4318> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff27aa1000 - 0x7fff27af3ff7 com.apple.HIServices (1.22 - 622) <2E83CD6F-ED98-3C29-BD0A-8525E38AB5DB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff27af4000 - 0x7fff27b02fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <71A9C815-AC55-3E36-A618-F6778F5119AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff27b03000 - 0x7fff27b4ffff com.apple.print.framework.PrintCore (13 - 503) <A69E2BAD-2B66-38CC-9D3A-0A0EBC41341D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff27b50000 - 0x7fff27b8afff com.apple.QD (3.12 - 403) <38D8106A-4FFA-3FE9-9999-714CADD7EE9C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff27b8b000 - 0x7fff27b97fff com.apple.speech.synthesis.framework (7.2.1 - 7.2.1) <BA7EDC49-E216-3D96-A7B7-8C76B862D484> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff27b98000 - 0x7fff27e23ff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <71699B6E-8B94-39E2-801F-8467C2B5B621> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff27e25000 - 0x7fff27e25fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <28C7FC0C-D2E5-3703-916F-866A0F823229> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff2813a000 - 0x7fff284ccfff com.apple.CFNetwork (893.13.1 - 893.13.1) <567231F4-4080-3B2D-8349-9177BD358804> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff284e1000 - 0x7fff284e1fff com.apple.Carbon (158 - 158) <FCD7A9FF-5E53-3B0C-8A52-691C11B2A0C5> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff284e2000 - 0x7fff284e5ffb com.apple.CommonPanels (1.2.6 - 98) <39C8EBA3-EEB2-335B-8A88-D6C64BAA112F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff284e6000 - 0x7fff287ebff7 com.apple.HIToolbox (2.1.1 - 910.4) <ADBE7A1B-0402-369C-A6F3-494E8CACD619> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff287ec000 - 0x7fff287efffb com.apple.help (1.3.8 - 64) <18D02016-119A-33E8-AEB0-E9466BA4AD56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff287f0000 - 0x7fff287f5fff com.apple.ImageCapture (9.0 - 9.0) <2DE590E5-DF0E-3962-A2BE-06EBC79B3D72> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff287f6000 - 0x7fff2888bffb com.apple.ink.framework (10.9 - 220) <D8AECAE3-9FD2-32E3-B659-026F33650BB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff2888c000 - 0x7fff288a6ff7 com.apple.openscripting (1.7 - 174) <66899B51-ADFD-360D-88E9-B52439F531B4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff288c7000 - 0x7fff288c8fff com.apple.print.framework.Print (12 - 267) <E4CBAAFC-9045-38AC-9F93-8C931DDED9D8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff288c9000 - 0x7fff288cbff7 com.apple.securityhi (9.0 - 55006) <E7668200-B4CB-3612-96B8-D57E94077787> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff288cc000 - 0x7fff288d2fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1F10ED1F-12C7-39AC-88A0-43A1338F9316> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff289df000 - 0x7fff289dffff com.apple.Cocoa (6.11 - 22) <F1AED1E8-ACC2-31F0-B85E-17E41167FC88> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff289ed000 - 0x7fff28aa6ff7 com.apple.ColorSync (4.13.0 - 546) <A5E013D9-7305-3026-879E-4D1F038A430D> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff28c33000 - 0x7fff28cc6ff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <4DE794D4-F018-31E8-B3CE-CF8DBE68D14E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff28d2d000 - 0x7fff28d56ffb com.apple.CoreBluetooth (1.0 - 1) <942F88A5-AD68-3359-90D5-6F1A3311C51A> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff28d57000 - 0x7fff290abfe7 com.apple.CoreData (120 - 849.2) <4407C44B-34CC-3D23-AEDF-AD866D414EBF> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff290ac000 - 0x7fff29178fff com.apple.CoreDisplay (1.0 - 81.7) <CE6B9237-B33D-3D8F-8C1C-4F57BD810D24> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff29179000 - 0x7fff29619fff com.apple.CoreFoundation (6.9 - 1450.16) <23F8373A-FA3F-37A2-BA5B-70061BFCCD21> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff2961b000 - 0x7fff29c28fef com.apple.CoreGraphics (2.0 - 1129.5) <F37BFBD2-CC21-3521-B034-9D4D36197487> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff29c2a000 - 0x7fff29f19fff com.apple.CoreImage (13.0.0 - 579.2.9) <B5661FF7-7558-308E-A3B7-C280F7A1DA78> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff2a1a8000 - 0x7fff2a288ff7 com.apple.CoreMedia (1.0 - 2267.40.5) <AE634D2B-FEB5-3669-80CC-F1C238698D44> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff2a2d8000 - 0x7fff2a2d8fff com.apple.CoreServices (822.19 - 822.19) <0C60B639-4CC4-3F57-BC5E-DB71EB75F7F4> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff2a2d9000 - 0x7fff2a34dffb com.apple.AE (735.1 - 735.1) <D0C73200-90A7-3FD1-A6EC-97055AA367E2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff2a34e000 - 0x7fff2a625ff7 com.apple.CoreServices.CarbonCore (1178.2 - 1178.2) <A1FE74F8-953B-371E-A8AC-E87B30FB79C6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff2a626000 - 0x7fff2a65aff7 com.apple.DictionaryServices (1.2 - 284) <3FCEE280-8DD0-37C9-BFD4-7BA87AAFC8EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff2a65b000 - 0x7fff2a663ff3 com.apple.CoreServices.FSEvents (1239 - 1239) <7BBC5CB7-DBC8-316B-99B0-781827159A2F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff2a664000 - 0x7fff2a81cff7 com.apple.LaunchServices (822.19 - 822.19) <F3AC96C3-0B52-3AA9-9DA8-288BBC523C07> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff2a81d000 - 0x7fff2a8ccff7 com.apple.Metadata (10.7.0 - 1191.2.6) <FB66B298-D55D-398A-BEDB-CB7B82956AE5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff2a8cd000 - 0x7fff2a92aff7 com.apple.CoreServices.OSServices (822.19 - 822.19) <408FB1A4-58E9-34D4-8022-A9EEC8502762> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff2a92b000 - 0x7fff2a999fff com.apple.SearchKit (1.4.0 - 1.4.0) <14053F88-2C76-35CA-9FC1-2A9BC0B63F88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff2a99a000 - 0x7fff2a9beffb com.apple.coreservices.SharedFileList (71.4 - 71.4) <4AA6DCF5-BAF8-36FA-A8B0-EDF518EFEF14> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff2ac68000 - 0x7fff2adb6ffb com.apple.CoreText (352.0 - 578.12) <DA0BC559-277A-32BA-91EA-FD2F02EA186F> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff2adb7000 - 0x7fff2adf1ff3 com.apple.CoreVideo (1.8 - 279.2) <A8FC5325-D092-3A28-A1CF-5C94B8101F71> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff2adf2000 - 0x7fff2ae7cffb com.apple.framework.CoreWLAN (13.0 - 1339) <FFA24EBB-75A1-3B33-9B26-96BDAF758CC0> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff2b00a000 - 0x7fff2b015ff7 com.apple.DirectoryService.Framework (10.13 - 207) <79F272D7-48AE-3D1E-AC5B-3CEB5F16E7D5> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff2b016000 - 0x7fff2b0d0fff com.apple.DiscRecording (9.0.3 - 9030.4.5) <2094BAC4-4F37-3741-B9BD-60158A63C503> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff2b0f7000 - 0x7fff2b0fcfff com.apple.DiskArbitration (2.7 - 2.7) <44836CE9-A9ED-3017-972A-7A0A3D6B472B> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff2b2bd000 - 0x7fff2b682fff com.apple.Foundation (6.9 - 1450.16) <7FEC6610-70EA-3A8D-8EC4-7E99BAF1E312> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff2b6f2000 - 0x7fff2b722fff com.apple.GSS (4.0 - 2.0) <3B4B4509-B5A3-396B-9C71-80BAE84476FA> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff2b834000 - 0x7fff2b937ff3 com.apple.Bluetooth (6.0.2 - 6.0.2f2) <AFC4A40B-AE56-3C53-A2B1-D0D9C335E21D> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff2b997000 - 0x7fff2ba32fff com.apple.framework.IOKit (2.0.2 - 1445.31.1) <7556086A-EFAF-3262-9822-6F666CFC6655> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff2ba34000 - 0x7fff2ba3bffb com.apple.IOSurface (209.2.2 - 209.2.2) <6D35A601-1C47-37BE-AD31-F8EB88F67573> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff2ba92000 - 0x7fff2bc09ff7 com.apple.ImageIO.framework (3.3.0 - 1713) <DB207AD2-06B5-3065-976B-F53C477D79C0> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff2bc0a000 - 0x7fff2bc0effb libGIF.dylib (1713) <C65B2846-1B94-3BB3-BBBF-5A9E5054CE1E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff2bc0f000 - 0x7fff2bcf6fff libJP2.dylib (1713) <8323253E-278A-3486-801A-83E143C19712> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff2bcf7000 - 0x7fff2bd1aff7 libJPEG.dylib (1713) <2D846A18-D8AF-3573-803B-BEABCBAC38D1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff2bff6000 - 0x7fff2c01cfeb libPng.dylib (1713) <546F41CE-185C-31A0-B61C-1012AA932624> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff2c01d000 - 0x7fff2c01fffb libRadiance.dylib (1713) <31787C46-4A2B-3CDF-95E9-EC1BD4794917> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff2c020000 - 0x7fff2c06dfeb libTIFF.dylib (1713) <5319B2E1-83D2-30C7-A7BC-A0CE0B07885D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff2c229000 - 0x7fff2cd8fff7 com.apple.JavaScriptCore (13604 - 13604.4.7.1.3) <3ACE94F3-B9B6-38FD-9CE7-7B44F374C143> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff2cd90000 - 0x7fff2cd98fff JavaNativeFoundation (74) <3D73481D-DD87-364C-8910-4A2AA5AA62B1> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
0x7fff2cd99000 - 0x7fff2cda1ff3 com.apple.java.JavaRuntimeSupport (15.0.1 - 15.0.1) <60A69FD7-4046-36C4-838F-AD07F9F17A2D> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
0x7fff2cda2000 - 0x7fff2cda6fff com.apple.JavaVM (15.0.2 - 15.0.2) <FA6D9BE2-DA78-3651-A1DA-9833AD7529DD> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x7fff2cda7000 - 0x7fff2cdc0ff7 com.apple.Kerberos (3.0 - 1) <CAF075C0-4C24-3ACE-9AE6-77BEFDEA3622> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff2cdc1000 - 0x7fff2cdf6fff com.apple.LDAPFramework (2.4.28 - 194.5) <8419BDB5-12DF-3BC9-871D-7A270E080249> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff2d078000 - 0x7fff2d07ffff com.apple.MediaAccessibility (1.0 - 114) <D72C593A-AC32-3419-AB86-6B07217EBFD5> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff2d122000 - 0x7fff2d73bff7 com.apple.MediaToolbox (1.0 - 2267.40.5) <BC84C8E1-FC56-3996-9110-E1BEF85587F7> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff2d73d000 - 0x7fff2d7bcfff com.apple.Metal (124.7 - 124.7) <C266564D-21B5-3FD9-92D5-03974F3186C4> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff2d7d9000 - 0x7fff2d7eefff com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <D4BCBA84-AD1B-33DC-99F3-16F9E5E50906> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff2d7ef000 - 0x7fff2d85afef com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <E504EC97-FAD7-36DC-B151-6F89AB911E3A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff2d85b000 - 0x7fff2d87efff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <A5B6F6FC-A19A-32C0-A999-98B6688760C7> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff2d87f000 - 0x7fff2d8ffff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <D0D8F13F-ACD4-3B61-BE54-121CCB05ECF4> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff2d900000 - 0x7fff2d900ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <2E8723FC-AA53-3596-B6A4-220A378B7A5A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff2e909000 - 0x7fff2e915ffb com.apple.NetFS (6.0 - 4.0) <81B22AE7-7094-30F2-BF41-84CA05EDB95B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff316fd000 - 0x7fff31705fef libcldcpuengine.dylib (2.8.7) <DD781325-D94E-3AD7-8D6C-817FB3068917> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff31706000 - 0x7fff31753ffb com.apple.opencl (2.8.12 - 2.8.12) <0AACB21D-AAC4-337C-8FF6-A8F6196614EE> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff31754000 - 0x7fff31770ffb com.apple.CFOpenDirectory (10.13 - 207) <7664F745-96E0-3F9F-964B-6014928902FB> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff31771000 - 0x7fff3177cfff com.apple.OpenDirectory (10.13 - 207) <1550BB27-D605-398C-8670-48700C86D674> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff328fb000 - 0x7fff328fdfff libCVMSPluginSupport.dylib (16.4.2) <A967BC8B-ABB3-393F-BF34-BD32B45831F7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff328fe000 - 0x7fff32902ff7 libCoreFSCache.dylib (162.4) <B325B709-0C81-357A-B9F1-6E0027B64F9B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff32903000 - 0x7fff32907fff libCoreVMClient.dylib (162.4) <B129DB84-39BA-34E4-9FB7-20A020A1BB86> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff32908000 - 0x7fff32910fff libGFXShared.dylib (16.4.2) <07F1D947-F79B-3608-9080-E4DBFE13AF1D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff32911000 - 0x7fff3291cfff libGL.dylib (16.4.2) <97D6871A-BAF1-33DD-9ED7-BE7BB437F378> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff3291d000 - 0x7fff32958fe7 libGLImage.dylib (16.4.2) <3E2802DF-4998-31DB-B3A2-65720DE919A5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff32959000 - 0x7fff32ac5fff libGLProgrammability.dylib (16.4.2) <3505EF20-FA3D-321B-8C11-D9CA74656F30> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff32ac6000 - 0x7fff32b04ffb libGLU.dylib (16.4.2) <ECABCFAB-E400-3667-8EE1-586C07E0E214> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff3347c000 - 0x7fff3348affb com.apple.opengl (16.4.2 - 16.4.2) <C8C31EF5-8DB4-336F-A87C-5D520C7EFDC5> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff3348b000 - 0x7fff33622ffb GLEngine (16.4.2) <8F35484D-9C09-3D79-9825-7E73661326D4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff33623000 - 0x7fff3364bffb GLRendererFloat (16.4.2) <463BD481-6E1A-3EFC-A93B-C7E9292F76ED> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff342d2000 - 0x7fff3451afff com.apple.QuartzCore (1.11 - 584.8.94) <8D6B5735-852F-36D3-9349-C423582F743B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff34d53000 - 0x7fff3506afff com.apple.security (7.0 - 58286.31.2) <D31B36DF-8956-3205-BFBA-98732DA715E5> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff3506b000 - 0x7fff350f5ff7 com.apple.securityfoundation (6.0 - 55185.30.4) <A1201529-3718-31C4-9D9E-BBD2A04B6751> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff350f6000 - 0x7fff35126ff3 com.apple.securityinterface (10.0 - 55109.30.2) <B305DA7D-7866-3194-B498-F9995D232486> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff35127000 - 0x7fff3512affb com.apple.xpc.ServiceManagement (1.0 - 1) <B11C3C64-6FE7-3A78-B583-D790B7CCE95A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff354cf000 - 0x7fff3553fff3 com.apple.SystemConfiguration (1.17 - 1.17) <3C6B2BB9-43AB-39AD-8027-38E30A8A4186> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff356f4000 - 0x7fff35a6dff7 com.apple.VideoToolbox (1.0 - 2267.40.5) <CC88FFB3-5DBE-33C0-AF8D-2C915D915A24> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff35d15000 - 0x7fff3622efe3 libwebrtc.dylib (7604.4.7.1.3) <777100A8-D98C-3DC1-931C-BBC689345FA2> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7fff3622f000 - 0x7fff376cbfff com.apple.WebCore (13604 - 13604.4.7.1.3) <FD0252AD-1BF9-30EE-BF2E-4409722582EB> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff376cc000 - 0x7fff378bdff7 com.apple.WebKitLegacy (13604 - 13604.4.7.1.3) <91DD2BFE-AA52-38AD-920C-D21D22ECA1B3> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff378be000 - 0x7fff37cadfff com.apple.WebKit (13604 - 13604.4.7.1.3) <E9C0A9B5-5331-3FDE-9587-968A86981D53> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff3811d000 - 0x7fff381a9ff7 com.apple.APFS (1.0 - 1) <834EAD5F-0C4E-3C33-A654-8E1670CEC457> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff38d6b000 - 0x7fff38d86ff3 com.apple.AppContainer (4.0 - 360.30.1) <65A03D4F-1DD8-35CE-B228-BD470CD35689> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff38db7000 - 0x7fff38ddffff com.apple.framework.Apple80211 (13.0 - 1345) <BD86685B-6221-300D-9A97-119285C43DE9> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff38de1000 - 0x7fff38df0ff7 com.apple.AppleFSCompression (96.30.2 - 1.0) <CFA90544-68EB-3CCE-A8F7-1B03974F3B85> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff38f2c000 - 0x7fff38f74ff3 com.apple.AppleJPEG (1.0 - 1) <8BBD5180-5BF9-33DB-8B91-974B1D0AECFB> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff38fa6000 - 0x7fff38faeff3 com.apple.AppleSRP (5.0 - 1) <4CEC34CF-63E3-3023-B61B-F8D133698534> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff38faf000 - 0x7fff38fd7fff com.apple.applesauce (1.0 - ???) <32FF4851-2F68-35BA-835F-91856A20C323> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff390a4000 - 0x7fff390f4ff7 com.apple.AppleVAFramework (5.0.39 - 5.0.39) <4B830521-2A54-3116-8103-127E631FEDC8> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff397c3000 - 0x7fff397caff7 com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <47B6301F-D908-3811-BB9E-DA16D9B29A34> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff397cb000 - 0x7fff39852ff7 com.apple.backup.framework (1.9.2 - 1.9.2) <40C6CFA8-4013-3AFB-97CE-8A09388FA343> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff3b1d5000 - 0x7fff3b1e0ffb com.apple.CommerceCore (1.0 - 654.8) <8774AB32-E5A1-3257-A631-F0C96CB56824> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff3b1e1000 - 0x7fff3b1eaff3 com.apple.CommonAuth (4.0 - 2.0) <11B2D184-36B8-3624-B1AD-7B6037D76160> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff3b47b000 - 0x7fff3b85bfff com.apple.CoreAUC (249.0.0 - 249.0.0) <7F406271-A215-3C75-BDAA-B9611BA2822E> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff3b85c000 - 0x7fff3b88cff7 com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <D0879D8F-488A-3D46-BC50-AD7B0642C0E8> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff3ba87000 - 0x7fff3ba90ff7 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <0A87A91C-A2CF-3BB1-9038-7F610111BC30> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff3bbf7000 - 0x7fff3bc07ff7 com.apple.CoreEmoji (1.0 - 69.3) <A4357F5C-0C38-3A61-B456-D7321EB2CEE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff3c61a000 - 0x7fff3c677ff7 com.apple.CoreNLP (1.0 - 130.4.1) <1F329E38-E7D0-3455-981B-48F434C9E8CC> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff3c800000 - 0x7fff3c805ff7 com.apple.CoreOptimization (1.0 - 1) <785B622B-8F7D-3B4D-83AF-EB98CB79FFF6> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
0x7fff3c954000 - 0x7fff3c9b0fff com.apple.CorePrediction (1.0 - 1) <B1E687BA-4E62-321B-8C87-D37C540A5A68> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
0x7fff3cadd000 - 0x7fff3cb0eff3 com.apple.CoreServicesInternal (309.1 - 309.1) <EB09CAFC-AE9B-3257-BE45-5471D9F64AAD> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff3ce5d000 - 0x7fff3ceeefff com.apple.CoreSymbolication (63075) <2458D96C-1C31-34F8-93F0-73DB0042CB30> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff3cf71000 - 0x7fff3d0a5fff com.apple.coreui (2.1 - 492.2) <FE0B32BC-958D-3445-866E-A3905626396D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff3d0a6000 - 0x7fff3d1b1ff3 com.apple.CoreUtils (5.3 - 530.57) <1DE5249E-35C5-3B13-BA5B-0C1AA4E17CDD> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff3d206000 - 0x7fff3d26afff com.apple.framework.CoreWiFi (13.0 - 1339) <1741FD6D-3DF2-3D2D-9B56-92A6AA0D1146> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff3d26b000 - 0x7fff3d27aff7 com.apple.CrashReporterSupport (10.13 - 1) <6B5B2B78-15D2-363F-BE34-8F9226E79E24> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff3d2f7000 - 0x7fff3d306ff7 com.apple.framework.DFRFoundation (1.0 - 191.1) <09E9A14C-E7A8-3386-8323-270FA28BFB81> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff3d309000 - 0x7fff3d30dffb com.apple.DSExternalDisplay (3.1 - 380) <BEC07C7C-F3AC-3CF3-B13E-3EBFD6224C0D> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff3d393000 - 0x7fff3d409fff com.apple.datadetectorscore (7.0 - 590.3) <792593BC-21C7-3E0C-929E-067CD725FCBD> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff3d457000 - 0x7fff3d497ff7 com.apple.DebugSymbols (141 - 141) <99562E28-0E56-3F6F-93A1-EF997A5E1F87> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff3d498000 - 0x7fff3d5c7fff com.apple.desktopservices (1.12.2 - 1.12.2) <8E068AF7-FB72-38E2-948E-6C13F359C69D> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff3d6b9000 - 0x7fff3d78bff7 com.apple.DiskImagesFramework (480.30.2 - 480.30.2) <251D047D-D79A-3300-8DFC-D6D6D4D0015D> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff3d78c000 - 0x7fff3d803ff7 com.apple.DiskManagement (11.2 - 1339) <0B17E79A-0BF6-3FD8-8AD0-A8498545030F> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff3d897000 - 0x7fff3d899ff7 com.apple.EFILogin (2.0 - 2) <5B6E5A73-C2B2-3188-ADE9-C29CE29BB225> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff3e33b000 - 0x7fff3e769fff com.apple.vision.FaceCore (3.3.2 - 3.3.2) <80C97AD7-D5C2-311A-B268-4AA60CAD6CED> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff3e773000 - 0x7fff3e795fff com.apple.framework.familycontrols (4.1 - 410) <E1B7D26E-5A27-3844-868C-3609621124FF> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff403d1000 - 0x7fff403d1fff libmetal_timestamp.dylib (802.3.14) <D2CD48A8-5989-32AC-B64B-76E29D4E2449> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3802/Libraries/libmetal_timestamp.dylib
0x7fff41a31000 - 0x7fff41a3cff7 libGPUSupportMercury.dylib (16.4.2) <F5BA5D7A-FD23-3416-B9B3-7EABFD4279D5> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff4277d000 - 0x7fff4278cfff com.apple.GraphVisualizer (1.0 - 5) <0A93C5DE-0D28-312E-8764-6B0FB805ED91> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff42804000 - 0x7fff42878fff com.apple.Heimdal (4.0 - 2.0) <ACC132E5-97F1-3B36-AD7B-4E6CC077E691> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff43120000 - 0x7fff43129fff com.apple.IOAccelMemoryInfo (1.0 - 1) <E062BBA9-0857-384E-978B-4C6346825E51> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff4312a000 - 0x7fff43131ffb com.apple.IOAccelerator (376.6 - 376.6) <A47129CC-F386-3C31-AD66-C19A70615A50> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff43135000 - 0x7fff4314cfff com.apple.IOPresentment (1.0 - 32.1) <B95F06EA-9D5D-311D-9912-978AE42ECFCE> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff43516000 - 0x7fff4353bfff com.apple.IconServices (97.4 - 97.4) <C84A6CA5-8C50-3288-8572-CC3DABF5BBCE> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff436d3000 - 0x7fff436d7fff JavaLaunching (42) <FE971877-2EE4-33CA-89BA-A8C8DE711641> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
0x7fff437d0000 - 0x7fff438c5fff com.apple.LanguageModeling (1.0 - 159.3.1) <9B08E18E-69B4-3413-A03A-EF5AE4BE6277> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff438c6000 - 0x7fff43908ff7 com.apple.Lexicon-framework (1.0 - 33.2) <5CC5E8EE-62A1-3EA5-B300-A39ABD0CF12D> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff4390c000 - 0x7fff43913ff7 com.apple.LinguisticData (1.0 - 238.3) <228AF7CA-649A-3E24-BBC7-8A24B39B3FC4> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff439fa000 - 0x7fff439fffff com.apple.LoginUICore (4.0 - 4.0) <A5F2EF2E-0999-376D-83EF-1B66171C5723> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff44137000 - 0x7fff4413afff com.apple.Mangrove (1.0 - 1) <13832222-8A6B-3790-8914-BE874B5ED4DD> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff44253000 - 0x7fff44286ff7 com.apple.MediaKit (16 - 871) <47A5B872-4139-315D-A047-581F9C485D15> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff4455f000 - 0x7fff445c8ff7 com.apple.gpusw.MetalTools (1.0 - 1) <F77943BC-0466-3700-BEDF-CDD13125D36A> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff445d0000 - 0x7fff445e5ff3 com.apple.MobileAssets (1.0 - 437.30.17) <9C014350-D76E-3143-ACFF-F3D1B2668988> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
0x7fff447e0000 - 0x7fff44808fff com.apple.MultitouchSupport.framework (1204.13 - 1204.13) <6C5D778D-4AB7-39A4-989B-2E8D2D57B3A0> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff44a6d000 - 0x7fff44a78fff com.apple.NetAuth (6.2 - 6.2) <5C6F492A-28EF-3A0E-B573-6F3D60CFF0C7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff4627a000 - 0x7fff462baffb com.apple.PerformanceAnalysis (1.183.1 - 183.1) <2BE359F2-DCE6-3E33-BA99-964507A3F540> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff48042000 - 0x7fff48095fff com.apple.ProtectedCloudStorage (1.0 - 1) <8C4D5271-406F-3455-88FA-995A95D6D4A1> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff48096000 - 0x7fff480b4fff com.apple.ProtocolBuffer (1 - 259) <D047A3FE-C7A8-3CAA-9891-6232BA88C247> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff48294000 - 0x7fff482b7ffb com.apple.RemoteViewServices (2.0 - 125) <AEDBCE8C-88B7-315A-9F81-3E068F0D3EDC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff49a76000 - 0x7fff49a79ff3 com.apple.SecCodeWrapper (4.0 - 360.30.1) <B57C5AE8-273E-37EA-BB26-B7671BF41E10> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff49bd0000 - 0x7fff49ce0ff7 com.apple.Sharing (972.6 - 972.6) <2F72F828-7A05-345F-8ABA-1EDADACA4D57> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff49d0a000 - 0x7fff49d0bfff com.apple.performance.SignpostNotification (1.0 - 1) <D4C967BA-92C6-3BAB-AFB5-59F98B35F921> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotification
0x7fff4aa08000 - 0x7fff4aca2fff com.apple.SkyLight (1.600.0 - 312.23.4) <390012E0-39E3-3D18-8271-D447990FDD21> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff4b453000 - 0x7fff4b460ff7 com.apple.SpeechRecognitionCore (4.0.13 - 4.0.13) <AC026FB9-78F8-31F9-BB80-619D5378DB70> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff4b8f9000 - 0x7fff4b920ff7 com.apple.StreamingZip (1.0 - 1) <F06F4CDC-138C-3991-A987-7C7332BE4508> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
0x7fff4bff2000 - 0x7fff4c076fe7 com.apple.Symbolication (9.0 - 63079.1) <177BC9CA-E6AE-3B40-806F-0080C0CDFF29> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff4c338000 - 0x7fff4c364fff com.apple.framework.SystemAdministration (1.0 - 1.0) <6AE03DE8-E5C1-38E5-B788-0A763CAACDC2> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff4c567000 - 0x7fff4c56eff3 com.apple.TCC (1.0 - 1) <C807D3F0-FE20-3FC0-8D61-306477ABEBC4> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff4c77b000 - 0x7fff4c838ff7 com.apple.TextureIO (3.7 - 3.7) <C98BFACA-7807-3DCA-945D-58EBA2B723C8> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff4c8dc000 - 0x7fff4c8ddfff com.apple.TrustEvaluationAgent (2.0 - 31) <39F533B2-211E-3635-AF47-23F27749FF4A> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff4c8e3000 - 0x7fff4ca92ff3 com.apple.UIFoundation (1.0 - 546.1.1) <2B50EBBC-9221-31BC-92A9-7ED0A4A46E2D> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff4d75b000 - 0x7fff4d82aff7 com.apple.ViewBridge (343.2 - 343.2) <DD3D1ED5-DF9E-3C48-8897-0B84B0AD2377> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff4e1d5000 - 0x7fff4e1d7ffb com.apple.loginsupport (1.0 - 1) <5E2C4AA7-066D-3FDB-B0E1-4CDAF287392C> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff4e33b000 - 0x7fff4e36efff libclosured.dylib (519.2.2) <48051216-5647-3643-B979-B77D0FD20011> /usr/lib/closure/libclosured.dylib
0x7fff4e40e000 - 0x7fff4e447ff7 libCRFSuite.dylib (41) <AB2DA745-F22C-30CF-81D4-35DD716463B8> /usr/lib/libCRFSuite.dylib
0x7fff4e448000 - 0x7fff4e453fff libChineseTokenizer.dylib (28) <D30A7DB6-058F-3286-9583-60C9EEB77A6E> /usr/lib/libChineseTokenizer.dylib
0x7fff4e454000 - 0x7fff4e4e1ff7 libCoreStorage.dylib (546) <B495D87B-FE21-3C14-9017-F02D9CA226D5> /usr/lib/libCoreStorage.dylib
0x7fff4e4e5000 - 0x7fff4e4e6ff3 libDiagnosticMessagesClient.dylib (104) <9712E980-76EE-3A89-AEA6-DF4BAF5C0574> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff4e51d000 - 0x7fff4e6e7ff3 libFosl_dynamic.dylib (17.7) <B2476843-7FA7-3E62-B79F-2B15FE557E63> /usr/lib/libFosl_dynamic.dylib
0x7fff4e71f000 - 0x7fff4e71ffff libOpenScriptingUtil.dylib (174) <203D2C39-61BB-3713-A502-2D17B04A42AC> /usr/lib/libOpenScriptingUtil.dylib
0x7fff4e848000 - 0x7fff4e84cffb libScreenReader.dylib (562.13) <21638ECC-87BF-3CC5-B2D8-6F7883F5FDCA> /usr/lib/libScreenReader.dylib
0x7fff4e84d000 - 0x7fff4e84eff3 libSystem.B.dylib (1252) <5EDEEA85-0387-31EE-9D9B-DA1B75E7AEF3> /usr/lib/libSystem.B.dylib
0x7fff4e8cd000 - 0x7fff4e8cefff libThaiTokenizer.dylib (2.2) <04AC7CD4-BD9A-3B1D-8CEB-9E2030B6B667> /usr/lib/libThaiTokenizer.dylib
0x7fff4e8e1000 - 0x7fff4e8e1fff libapple_crypto.dylib (109.30.8) <E0162198-C97F-3286-9FF7-254D23F6FD04> /usr/lib/libapple_crypto.dylib
0x7fff4e8e2000 - 0x7fff4e8f8ff7 libapple_nghttp2.dylib (1.24) <01402BC4-4822-3676-9C80-50D83F816424> /usr/lib/libapple_nghttp2.dylib
0x7fff4e8f9000 - 0x7fff4e923ff3 libarchive.2.dylib (54) <8FC28DD8-E315-3C3E-95FE-D1D2CBE49888> /usr/lib/libarchive.2.dylib
0x7fff4e924000 - 0x7fff4e9a5fdf libate.dylib (1.13.1) <178ACDAD-DE7E-346C-A613-1CBF7929AC07> /usr/lib/libate.dylib
0x7fff4e9a9000 - 0x7fff4e9a9ff3 libauto.dylib (187) <A05C7900-F8C7-3E75-8D3F-909B40C19717> /usr/lib/libauto.dylib
0x7fff4e9aa000 - 0x7fff4ea61ff7 libboringssl.dylib (109.30.8) <E62E3E83-BA8A-3CCE-8E71-84FB184FBBB5> /usr/lib/libboringssl.dylib
0x7fff4ea62000 - 0x7fff4ea72ff3 libbsm.0.dylib (39) <770B341F-3BB7-3123-B53C-F2D58868A963> /usr/lib/libbsm.0.dylib
0x7fff4ea73000 - 0x7fff4ea80ffb libbz2.1.0.dylib (38) <0A5086BB-4724-3C14-979D-5AD4F26B5B45> /usr/lib/libbz2.1.0.dylib
0x7fff4ea81000 - 0x7fff4ead7fff libc++.1.dylib (400.9) <FCF5E1F6-2B04-3545-8004-F3AB32FED172> /usr/lib/libc++.1.dylib
0x7fff4ead8000 - 0x7fff4eafcff7 libc++abi.dylib (400.7) <217656D5-BC40-37FF-B322-91CB2AAD4F34> /usr/lib/libc++abi.dylib
0x7fff4eafe000 - 0x7fff4eb0efff libcmph.dylib (6) <A5509EE8-7E00-3224-8814-015B077A3CF5> /usr/lib/libcmph.dylib
0x7fff4eb0f000 - 0x7fff4eb25fff libcompression.dylib (47) <E64D4416-DFBF-314B-BBB9-BED23C3A251C> /usr/lib/libcompression.dylib
0x7fff4edd2000 - 0x7fff4edeaff7 libcoretls.dylib (155) <DFE2454F-2FE3-3B2B-A22B-422947C34C69> /usr/lib/libcoretls.dylib
0x7fff4edeb000 - 0x7fff4edecffb libcoretls_cfhelpers.dylib (155) <D3F4B882-40C1-3CD4-927B-0E0ED6031D0B> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff4ef85000 - 0x7fff4f115fff libcrypto.35.dylib (22) <067CFC21-249D-392D-ADE1-785100BF0F83> /usr/lib/libcrypto.35.dylib
0x7fff4f2b0000 - 0x7fff4f2bbff7 libcsfde.dylib (546) <B6F6340A-F874-38BD-A7BB-FFADEBA54789> /usr/lib/libcsfde.dylib
0x7fff4f2bc000 - 0x7fff4f312ff3 libcups.2.dylib (462.1) <B78448A0-9C97-3D4A-823E-EBE37B2B7CA6> /usr/lib/libcups.2.dylib
0x7fff4f33d000 - 0x7fff4f391ffb libcurl.4.dylib (105.30.2) <DB7326B0-DE38-392D-AAFA-E81BE0EDE99E> /usr/lib/libcurl.4.dylib
0x7fff4f394000 - 0x7fff4f39bff3 libdscsym.dylib (183.1) <2DE012BF-CE9A-3BDF-9A2D-55D66B51AA35> /usr/lib/libdscsym.dylib
0x7fff4f450000 - 0x7fff4f450fff libenergytrace.dylib (16) <A92AB8B8-B986-3CE6-980D-D55090FEF387> /usr/lib/libenergytrace.dylib
0x7fff4f482000 - 0x7fff4f486ff7 libgermantok.dylib (17) <379C5DC6-BEDB-378D-B09C-A63D297EAA6D> /usr/lib/libgermantok.dylib
0x7fff4f487000 - 0x7fff4f48cff3 libheimdal-asn1.dylib (520.30.1) <14DC1451-6E22-3A48-80CB-5D33DC0F8C3B> /usr/lib/libheimdal-asn1.dylib
0x7fff4f4b8000 - 0x7fff4f5a9ff7 libiconv.2.dylib (51) <0772997F-4109-38A1-91ED-0F3F16AE99E5> /usr/lib/libiconv.2.dylib
0x7fff4f5aa000 - 0x7fff4f7d1ffb libicucore.A.dylib (59152.0.1) <281C39FD-0C9A-3EB2-A407-36D4CCE938E5> /usr/lib/libicucore.A.dylib
0x7fff4f81e000 - 0x7fff4f81ffff liblangid.dylib (128) <39C39393-0D05-301D-93B2-F224FC4949AA> /usr/lib/liblangid.dylib
0x7fff4f820000 - 0x7fff4f839ffb liblzma.5.dylib (10) <3D419A50-961F-37D2-8A01-3DC7AB7B8D18> /usr/lib/liblzma.5.dylib
0x7fff4f83a000 - 0x7fff4f850ff7 libmarisa.dylib (9) <D6D2D55D-1D2E-3442-B152-B18803C0ABB4> /usr/lib/libmarisa.dylib
0x7fff4f851000 - 0x7fff4f900fff libmecab.1.0.0.dylib (779.7.6) <F179766A-0448-37A6-9AD0-99E2FF2C0AD9> /usr/lib/libmecab.1.0.0.dylib
0x7fff4f901000 - 0x7fff4fb29ff7 libmecabra.dylib (779.7.6) <7808C544-161E-37CE-9D42-F368C82A180D> /usr/lib/libmecabra.dylib
0x7fff4fd01000 - 0x7fff4fdd8ffb libnetwork.dylib (1229.30.11) <2A9846DE-C063-3340-89D1-D5DAC2B8A08A> /usr/lib/libnetwork.dylib
0x7fff4fe4e000 - 0x7fff5023c7e7 libobjc.A.dylib (723) <93A92316-DE1E-378C-8891-99720B50D075> /usr/lib/libobjc.A.dylib
0x7fff5023d000 - 0x7fff5023eff7 libodfde.dylib (24) <1BBC519E-EF89-38F3-B226-70F086670D0F> /usr/lib/libodfde.dylib
0x7fff5024f000 - 0x7fff50253fff libpam.2.dylib (22) <7B4D2CE2-1438-387A-9802-5CEEFBF26F86> /usr/lib/libpam.2.dylib
0x7fff50256000 - 0x7fff5028afff libpcap.A.dylib (79.20.1) <FA13918B-A247-3181-B256-9B852C7BA316> /usr/lib/libpcap.A.dylib
0x7fff50309000 - 0x7fff50325ffb libresolv.9.dylib (65) <E8F3415B-4472-3202-8901-41FD87981DB2> /usr/lib/libresolv.9.dylib
0x7fff50360000 - 0x7fff50372fff libsasl2.2.dylib (211) <D9E281A2-D7BA-32CD-8B96-54972B1D9E66> /usr/lib/libsasl2.2.dylib
0x7fff50373000 - 0x7fff50374ff7 libspindump.dylib (248) <12E8B8BA-072F-39AE-8BC9-7D5840DA80EB> /usr/lib/libspindump.dylib
0x7fff50375000 - 0x7fff50508fe7 libsqlite3.dylib (274.5) <A1DEB5AB-8FE8-332E-A7E5-F493F2223FE3> /usr/lib/libsqlite3.dylib
0x7fff50564000 - 0x7fff505b7ffb libssl.35.dylib (22) <4D77B502-E065-3794-90E7-39E83F9683F6> /usr/lib/libssl.35.dylib
0x7fff5060a000 - 0x7fff50658fff libstdc++.6.0.9.dylib (104.1) <92CC5BBD-2FB2-3864-BF6B-B4B1BFF4C1EE> /usr/lib/libstdc++.6.0.9.dylib
0x7fff506d9000 - 0x7fff50712fff libusrtcp.dylib (1229.30.11) <537F14D0-84DF-349F-8EA0-52BB7A241E60> /usr/lib/libusrtcp.dylib
0x7fff50713000 - 0x7fff50716ffb libutil.dylib (51.20.1) <216D18E5-0BAF-3EAF-A38E-F6AC37CBABD9> /usr/lib/libutil.dylib
0x7fff50717000 - 0x7fff50724fff libxar.1.dylib (400) <0316128D-3B47-3052-995D-97B4FE5491DC> /usr/lib/libxar.1.dylib
0x7fff50728000 - 0x7fff5080ffff libxml2.2.dylib (31.7) <49544596-BCF8-3765-8DC5-DB1A9A90EF92> /usr/lib/libxml2.2.dylib
0x7fff50810000 - 0x7fff50838fff libxslt.1.dylib (15.10) <66682AF6-C2D5-374C-901F-25A3E72814DC> /usr/lib/libxslt.1.dylib
0x7fff50839000 - 0x7fff5084bffb libz.1.dylib (70) <48C67CFC-940D-3857-8DAD-857774605352> /usr/lib/libz.1.dylib
0x7fff508e9000 - 0x7fff508edff7 libcache.dylib (80) <354F3B7D-404E-3398-9EBF-65CA2CE65211> /usr/lib/system/libcache.dylib
0x7fff508ee000 - 0x7fff508f8ff3 libcommonCrypto.dylib (60118.30.2) <674286D3-7744-36A3-9AAA-49DFCD97A986> /usr/lib/system/libcommonCrypto.dylib
0x7fff508f9000 - 0x7fff50900fff libcompiler_rt.dylib (62) <4487CFBA-A5D7-3282-9E6B-94CAD7BE507E> /usr/lib/system/libcompiler_rt.dylib
0x7fff50901000 - 0x7fff50909ffb libcopyfile.dylib (146.30.2) <2C7C67D7-562B-3FFA-973D-BACF4C10E1EC> /usr/lib/system/libcopyfile.dylib
0x7fff5090a000 - 0x7fff5098ffff libcorecrypto.dylib (562.30.10) <8A53EFE1-AFCA-3676-BEE1-FA5ED9F0E222> /usr/lib/system/libcorecrypto.dylib
0x7fff50a17000 - 0x7fff50a50ff7 libdispatch.dylib (913.30.4) <7D0E3183-282B-3FEE-A734-2C0ADC092084> /usr/lib/system/libdispatch.dylib
0x7fff50a51000 - 0x7fff50a6eff7 libdyld.dylib (519.2.2) <C50D02BC-A333-3313-B787-02F255A6783F> /usr/lib/system/libdyld.dylib
0x7fff50a6f000 - 0x7fff50a6fffb libkeymgr.dylib (28) <6D84A96F-C65B-38EC-BDB5-21FD2C97E7B2> /usr/lib/system/libkeymgr.dylib
0x7fff50a70000 - 0x7fff50a7cff3 libkxld.dylib (4570.31.3) <C0DBCF74-E669-3AAD-934F-F07F3FE32908> /usr/lib/system/libkxld.dylib
0x7fff50a7d000 - 0x7fff50a7dff7 liblaunch.dylib (1205.30.29) <E66F58ED-C15E-3DFB-BC22-A861E13918C6> /usr/lib/system/liblaunch.dylib
0x7fff50a7e000 - 0x7fff50a82ffb libmacho.dylib (900.0.1) <756F2553-07B6-3B42-ACEA-2F0F1A5E8D0F> /usr/lib/system/libmacho.dylib
0x7fff50a83000 - 0x7fff50a85ff3 libquarantine.dylib (86) <6AC8773F-3817-3D82-99C2-01BABB9C3CBB> /usr/lib/system/libquarantine.dylib
0x7fff50a86000 - 0x7fff50a87ff3 libremovefile.dylib (45) <912FA211-DD8C-3C92-8424-21B89F8B10FD> /usr/lib/system/libremovefile.dylib
0x7fff50a88000 - 0x7fff50a9ffff libsystem_asl.dylib (356.1.1) <94972913-9DF0-3C78-847C-43E58919E3DA> /usr/lib/system/libsystem_asl.dylib
0x7fff50aa0000 - 0x7fff50aa0fff libsystem_blocks.dylib (67) <F2493BB5-B1C6-3C4D-9F1F-1B402E0F1DB7> /usr/lib/system/libsystem_blocks.dylib
0x7fff50aa1000 - 0x7fff50b2aff7 libsystem_c.dylib (1244.30.3) <E0136C71-0648-36F0-9F84-82EA2748A8D7> /usr/lib/system/libsystem_c.dylib
0x7fff50b2b000 - 0x7fff50b2effb libsystem_configuration.dylib (963.30.1) <0F8D0B76-4F7D-34EC-AB6C-50F9465809DA> /usr/lib/system/libsystem_configuration.dylib
0x7fff50b2f000 - 0x7fff50b32ffb libsystem_coreservices.dylib (51) <21A488D0-2D07-344E-8631-CC8B2A246F35> /usr/lib/system/libsystem_coreservices.dylib
0x7fff50b33000 - 0x7fff50b34fff libsystem_darwin.dylib (1244.30.3) <2F750CB1-BC26-3FA3-AE59-553EE30D451B> /usr/lib/system/libsystem_darwin.dylib
0x7fff50b35000 - 0x7fff50b3bff7 libsystem_dnssd.dylib (878.30.4) <EB9BB165-45A4-367C-B33A-688D4F383A95> /usr/lib/system/libsystem_dnssd.dylib
0x7fff50b3c000 - 0x7fff50b85ff7 libsystem_info.dylib (517.30.1) <7D79E167-4B5C-3833-81EE-3AF3FB53616D> /usr/lib/system/libsystem_info.dylib
0x7fff50b86000 - 0x7fff50babff7 libsystem_kernel.dylib (4570.31.3) <D2E842AA-3B8D-31BF-8234-8C1BE11CFE32> /usr/lib/system/libsystem_kernel.dylib
0x7fff50bac000 - 0x7fff50bf7fcb libsystem_m.dylib (3146) <ABB1B85F-9FFE-31B8-AD4F-E39A30794A93> /usr/lib/system/libsystem_m.dylib
0x7fff50bf8000 - 0x7fff50c17fff libsystem_malloc.dylib (140.1.1) <9F0745FF-B92F-330D-8812-BB74001D1D33> /usr/lib/system/libsystem_malloc.dylib
0x7fff50c18000 - 0x7fff50cbcff3 libsystem_network.dylib (1229.30.11) <40BAD301-8744-3AD8-A688-E7925C587B00> /usr/lib/system/libsystem_network.dylib
0x7fff50cbd000 - 0x7fff50cc7ffb libsystem_networkextension.dylib (767.30.7) <C5ED4BAB-2480-369D-8AB6-DFB37C15A1EE> /usr/lib/system/libsystem_networkextension.dylib
0x7fff50cc8000 - 0x7fff50cd1ff3 libsystem_notify.dylib (172) <98EA3D62-7C86-30DE-8261-D020D2F1EFF3> /usr/lib/system/libsystem_notify.dylib
0x7fff50cd2000 - 0x7fff50cd9ff7 libsystem_platform.dylib (161.20.1) <C049250F-8C35-314D-810F-4E28AEAED983> /usr/lib/system/libsystem_platform.dylib
0x7fff50cda000 - 0x7fff50ce5fff libsystem_pthread.dylib (301.30.1) <ABA848E1-6978-3B42-A3A7-608B2C36FA93> /usr/lib/system/libsystem_pthread.dylib
0x7fff50ce6000 - 0x7fff50ce9ff3 libsystem_sandbox.dylib (765.30.4) <A51828BA-26D8-3205-AF3A-DF5C37269468> /usr/lib/system/libsystem_sandbox.dylib
0x7fff50cea000 - 0x7fff50cebff3 libsystem_secinit.dylib (30) <F06ADB8F-9E94-34A7-B3C9-2C22FDD14BAD> /usr/lib/system/libsystem_secinit.dylib
0x7fff50cec000 - 0x7fff50cf3ff7 libsystem_symptoms.dylib (820.30.7) <DC3586C2-AA56-3419-88D3-FC0DBF08E3C0> /usr/lib/system/libsystem_symptoms.dylib
0x7fff50cf4000 - 0x7fff50d07ff7 libsystem_trace.dylib (829.30.14) <69EBF017-D40F-30D7-9B0B-BFC862D761A5> /usr/lib/system/libsystem_trace.dylib
0x7fff50d09000 - 0x7fff50d0eff7 libunwind.dylib (35.3) <6D4FCD49-D2A9-3233-95C7-A7635CE265F2> /usr/lib/system/libunwind.dylib
0x7fff50d0f000 - 0x7fff50d3bff7 libxpc.dylib (1205.30.29) <F7E5F1BC-614B-39CB-B6CE-92A9C7B7EC0B> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 36
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 23377801
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=427.5M resident=0K(0%) swapped_out_or_unallocated=427.5M(100%)
Writable regions: Total=4.8G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=4.8G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 3
Activity Tracing 256K 2
CG backing stores 40.7M 9
CG image 7228K 181
CoreAnimation 44K 5
CoreGraphics 8K 2
CoreImage 32K 5
CoreUI image data 1320K 15
CoreUI image file 292K 4
Foundation 28K 3
IOKit 7940K 2
Kernel Alloc Once 8K 2
MALLOC 434.9M 100
MALLOC guard page 64K 15
MALLOC_LARGE (reserved) 1152K 3 reserved VM address space (unallocated)
Memory Tag 242 12K 2
OpenGL GLSL 256K 4
STACK GUARD 560K 61
Stack 61.1M 61
Stack Guard 56.2M 41
VM_ALLOCATE 2.9G 69
VM_ALLOCATE (reserved) 2.5G 3 reserved VM address space (unallocated)
__DATA 30.9M 304
__FONT_DATA 4K 2
__GLSLBUILTINS 2588K 2
__LINKEDIT 197.6M 19
__TEXT 229.9M 301
__UNICODE 560K 2
mapped file 90.8M 567
shared memory 820K 15
TOTAL 6.6G 1774
TOTAL, minus reserved VM space 4.1G 1774
BlackNight
I'm not a Mac user/expert, so these are just some thoughts on this topic:
it seems to me that the problem is caused by the SWT/graphics libraries in Eclipse and what Apple has changed in High Sierra, causing problems with Eclipse in general.
There is a related thread here on this topic: MCUXpresso 10.0.2 Crash in macOS High Sierra (10.13)
That post includes an updated SWT.jar file (by Jeff Williams), maybe this helps for KDS (not sure, but might be worth a try).
Another option would be to check if Eclipse Oxygen does not expose that problem. In that case you could build up a 'KDS with Oxygen', similar to what I did Breathing with Oxygen: DIY ARM Cortex-M C/C++ IDE and Toolchain with Eclipse Oxygen | MCU on Eclipse : that way you could keep the toolchain and projects with Eclipse Oxygen.
I hope this helps,
Erich
tamermash
Unfortunately the swt.jar did not help. Here's the error:
!SESSION 2018-02-05 12:00:24.482 -----------------------------------------------
eclipse.buildId=3.2.0.201603041649
java.version=1.8.0_144
java.vendor=Oracle Corporation
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product com.somniumtech.branding.kds.ide
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product com.somniumtech.branding.kds.ide
!ENTRY org.eclipse.osgi 4 0 2018-02-05 12:00:26.764
!MESSAGE An error occurred while automatically activating bundle org.eclipse.ui.workbench (490).
!STACK 0
org.osgi.framework.BundleException: Error starting module.
at org.eclipse.osgi.container.Module.doStart(Module.java:580)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:391)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2671)
at java.lang.Class.getConstructor0(Class.java:3075)
at java.lang.Class.newInstance(Class.java:412)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:191)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:755)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:706)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
... 32 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.SWTError cannot be found by org.eclipse.ui.workbench_3.106.2.v20150204-1030
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:432)
... 41 more
Root exception:
... 41 more
!ENTRY org.eclipse.osgi 4 0 2018-02-05 12:00:26.774
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.ui.ide.application" was unable to instantiate class "org.eclipse.ui.internal.ide.application.IDEApplication".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/ui/application/WorkbenchAdvisor
... 15 more
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.ui.workbench (490).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
... 20 more
Caused by: org.osgi.framework.BundleException: Error starting module.
... 29 more
... 32 more
... 41 more
tamermash
I'm also trying to install and configure oxygen, but the instructions are for windows and some of it doesn't match on Mac. Do you guys have any Mac experts there that can help?
tamermash
Would be nice if someone at NXP would take responsibility and build a patch for KDS to fix this problem. I don't understand why NXP is refusing to take responsibility on this issue!!!
tamermash
I started looking at moving to MCUXpresso as looks like I have no choice; however, I have to manually install several components in order for it to work and the available instructions are windows only and they don't match the Mac installation as folders are not the same and the arm toolchain is not an installer, but a bunch of folders without even a readme file for installation instructions!!! If MCUXpresso is replacing KDS, then please do a better job at packaging it up. I don't understand why you guys can't provide a clean solution like Freescale did with KDS. KDS and processor expert were one of the main reasons we went with Freescale before it was bought!!
BlackNight
The instructions are more like a workaround for anyone who wants to migrate Processor Expert projects to MCUXpresso. I appologize for the issues you have. Processor Expert is left behind in KDS and not carried forward into MCUXpresso IDE and replaced with the Configuration Tools inside the MCUXpresso IDE. And I appologize as well for the Windows instructions, as I don't own a Mac maschine (I wish I would have one). So I very much feel with you, and I hope you understand the background. The truth is that Processor Expert and KDS is discontinued, and the MCUXpresso SDK and MCUXpression Configuration tools with the MCUXpresso IDE is the path moving forward.
