SCM-i.MX 6 SoloX spidev device tree (EVB-SCMIMX6SX)
robertomigliora
device tree edit help for spidev on SCM-i.MX 6 SoloX
I have these pins for SPI:
QSPI1B_DQS    =ECSPI5_SS0
QSPI1A_SS1_B    =ECSPI5_MISO
QSPI1A_DQS    =ECSPI5_MOSI
QSPI1B_SS1_B    =ECSPI5_SCLK
how can i edit the imx6sxscm-evb.dts file ?
thanks
jimmychan
This is the example for your reference:
Use the "pinctrl_qspi2" in imx6sx-sdb.dts
&qspi2 {
               pinctrl-names = "default";
               pinctrl-0 = <&pinctrl_qspi2>;
               status = "okay";
The "pinctrl_qspi2" is defined in imx6sx-sdb.dtsi
pinctrl_qspi2: qspi2grp {
               fsl,pins = <
                              MX6SX_PAD_NAND_WP_B__QSPI2_A_DATA_0     0x70f1
                              MX6SX_PAD_NAND_READY_B__QSPI2_A_DATA_1  0x70f1
                              MX6SX_PAD_NAND_CE0_B__QSPI2_A_DATA_2    0x70f1
                              MX6SX_PAD_NAND_CE1_B__QSPI2_A_DATA_3    0x70f1
                              MX6SX_PAD_NAND_CLE__QSPI2_A_SCLK        0x70f1
                              MX6SX_PAD_NAND_ALE__QSPI2_A_SS0_B       0x70f1
                              MX6SX_PAD_NAND_DATA01__QSPI2_B_DATA_0   0x70f1
                              MX6SX_PAD_NAND_DATA00__QSPI2_B_DATA_1   0x70f1
                              MX6SX_PAD_NAND_WE_B__QSPI2_B_DATA_2     0x70f1
                              MX6SX_PAD_NAND_RE_B__QSPI2_B_DATA_3     0x70f1
                              MX6SX_PAD_NAND_DATA02__QSPI2_B_SCLK     0x70f1
                              MX6SX_PAD_NAND_DATA03__QSPI2_B_SS0_B    0x70f1
For the pin name, please see the imx6sx-pinfunc.h
