MKW40Z reset waveform is strange
minjaekim
The board was made with MKW40Z.
It did not work and the reset was appeared as an attachment
What's the problem?
mjbcswitzerland
Specialist V
Either you haven't loaded any code to flash or the code loaded causes a crash immediately.
This is typical for the reset line in these cases.
Mark
