Latency/No of clock cycles of each Instructions
sagardhavali
I am looking for latency or number of clock cycles that each instructions takes in MPC5744P.
Any help is appreciated.
Thank You,
Sagar
davidtosenovjan
Hi, you may find in RM, table above:
Precondition for such timing is that executed code is stored in instruction cache and access only data already loaded in data cache (configured for copy-back mode).
Otherwise you must take into account other delays (stalls) caused by access to registers/memories over XBAR (and possibly PBRIDGE/EBI).
