I would like to use the ADC internal temperature sensor to measure the chip temperature, but I will not be configured, how to get the value of K. Can you give a reference example?
Solved! Go to Solution.
Temperature sensor seems to be the same implementation as on MPC5744P, thus following example could be useful for you:
Yes, I saw the example, but I do not know where the values of K1, k2,k3,k4 look, where is the text flash in the reference manual, how to get
It is located in UTEST memory:
Could you specify used MCU part number? Thanks
the MCU is 5775
If there is an example, that's the best。I want to learn its configuration
