About plugin
About plugin
xiaofangu
Hi,I encountered a problem.According to the pdf file named " Using NXP’s LIN Driver with the MagniV  Family ", it shows a plug-in for Eclipse and the plugin can create a .ldf file.So,would you show me where to download this plugin?By the way,i am using the V10.6 codewarrior.
Hello Xiaofan,
Please first download and  install the LIN Driver,
S12ZVM Evaluation Board|NXP
then you can find the plug-in and the
detail install guide "Eclipse_User_Manual.pdf"->3.1 Plug-in Setup . I also attached the user manual for you.
Hope it helps
TIC
