Is there any using method about mpc5748(0N78S/1N81M)?
seokwonkim
I use mpc5748 with X-MPC574XG-324DS, TRACE32.
When I used PPC5748GMMN6A / 1N81M, there was no problem for using this microcontroller.
But when I change the microcontroller to PPC5748GSMMN6 / 0N78S, TRACE32 cannot detect this microcontroller.
So I want to know if there is a different method using these two chips.
Thank you.
rweiss
Contributor V
What error messages do you get? Check the AREA window (Menu: View - Message Area).
Reinhard
seokwonkim
In message area I can see this message
JTAGID=0x0988201D
Processor with JTAGID 0x0988201D not supported by this debugger software version.
Get the latest software update from http://www.lauterbach.com/update.html and
try again. If the problem persists, contact support@lauterbach.com to request
a software update for your device.
debug hardware configuration error
Thank you
rweiss
Contributor V
Follow the instructions in the message: Install the latest software update.
Reinhard
seokwonkim
Thank you so much for your effort.
I solved my problem with your help:smileyhappy:
