Ltib Build Failed
Ltib Build Failed
samikshadubey
I am working on imx6sl processor with ltib setup.I want to use curl package due to some requirements.when i enable curl in package list by doing ./ltib -c it gives below  error and failed.
RPM build errors:
Bad exit status from /home/samiksha/NETC_PROJECT/subodh_sdko/netc_IG_sdk/Linux_BSP_IG/Linux_SDK_Revb/Kernel/Kernel/ltib/tmp/rpm-tmp.37200 (%build)
Build time for curl: 0 seconds
Failed building curl
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Fri Aug 11 10:23:28 2017
Ended: Fri Aug 11 10:23:39 2017
Elapsed: 11 seconds
These packages failed to build:
curl
Build Failed
Exiting on error or interrupt
Can anyone please help me out?
joanxie
what bsp versioin do  you use? did you build bsp successfully?
