S12XEP100's wdt(COP) is overflow, what is S12XEP100's behavior
tafengchung
S12XEP100's wdt(COP)  is overflow, what is S12XEP100's behavior.
i check the contents of ram data (0xFFFA/0xFFFB) is C193.
so if S12XEP100's wdt(COP)  is overflow, program count will be change c193?
my test code as below, when wdt is work, program is still work( wdt_reset() process  is seem not work )
static void wdt_reset(void){  // at 0xc193
      while(1){
      _FEED_COP();
static void por_reset(void)
    initial();
    run_normal_program();
