MMPF0100+IMAX6Q solution, produce 50pcs, 5 have power on problem,it can't start-up ,can't boot. Then give a reset signal on PMIC_STBY_REQ pin manually, it start-up and work well.
if power off and power on quickly within 1s, it also can boot and work well.
what's the problem??
Here recommand you to check your hardware power and PCB Welding problem.
