IAP program DUAL-BANK Flash
skysky
i want to use USB-way to update the APP program,and the size of program is bigger,need to use bank-A and bank-B.
but i don't know how to program the flash by the IAP.
So is there a example??
soledad
Please check the below link, and let me know if this helps.
Placing code/rodata into different FLASH blocks
Soledad
skysky
This explains how to put the program's code and data in different places of flash.
Instead of using IAP update user program.
soledad
Could you please mention which device are you using?
Soledad
skysky
the device is LPC4357.
i want to update my program by IAP instruction.
but i don't know how to operation when my program's size is bigger than one bank-512K.
you know,the IAP program is base on the BASE sector address and size.
But I don't know exactly what address and size my program takes。
Therefore, the exact parameters of the IAP command cannot be given.
