Wpa Supplicant Crashing while disconnect from connected Access Point
ThanarajS
Hi All,
   We have ported driver using NL80211 interface in Android 6 platform. Wi-Fi is up and connection established with Access point[Open/Secured].
After when we try to disconnect the connected Access point in android GUI, wpa_supplicant is crashing by signal 11.
Error Log:
action=android.net.conn.INET_CONDITION_ACTION
01-01 00:02:01.651   540   581 E WifiConfigStore:  rewrite network history for "Redmi"WPA_PSK
01-01 00:02:02.267  1273  1273 D wpa_supplicant: EAPOL: startWhen --> 0
01-01 00:02:02.267  1273  1273 D wpa_supplicant: EAPOL: disable timer tick
01-01 00:02:03.060   238   533 W audio_hw_primary: do_out_standby... -1243289856
01-01 00:02:03.385  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:03.385  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:03.386   540   583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 48
01-01 00:02:06.390  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:06.390  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:06.392   540   583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 46
01-01 00:02:08.949   540   583 D ConnectivityService: handlePromptUnvalidated 100
01-01 00:02:09.396  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:09.397  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:09.398   540   583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 44
01-01 00:02:11.264  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SCAN TYPE=ONLY'
01-01 00:02:11.264  1273  1273 D wpa_supplicant: wlan0: Setting scan request: 0.000000 sec
01-01 00:02:11.264  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=3
01-01 00:02:11.265  1273  1273 D wpa_supplicant: wlan0: Starting AP scan for wildcard SSID
01-01 00:02:11.265  1273  1273 D wpa_supplicant: wlan0: Add radio work 'scan'@0xb6bd90f0
01-01 00:02:11.265  1273  1273 D wpa_supplicant: wlan0: First radio work item in the queue - schedule start immediately
01-01 00:02:11.265  1273  1273 D wpa_supplicant: wlan0: Starting radio work 'scan'@0xb6bd90f0 after 0.000154 second wait
01-01 00:02:11.265  1273  1273 D wpa_supplicant: wlan0: nl80211: scan request
01-01 00:02:11.265  1273  1273 D wpa_supplicant: nl80211: Scan SSID - hexdump(len=0): [NULL]
01-01 00:02:11.265  1273  1273 D wpa_supplicant: nl80211: Scan extra IEs - hexdump(len=6): 7f 04 00 00 0a 02
01-01 00:02:11.266  1273  1273 D wpa_supplicant: Scan requested (ret=0) - scan timeout 30 seconds
01-01 00:02:11.266  1273  1273 D wpa_supplicant: RTM_NEWLINK: ifi_index=5 ifname=wlan0 wext ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWE)
01-01 00:02:11.266  1273  1273 D wpa_supplicant: nl80211: Event message available
01-01 00:02:11.266  1273  1273 D wpa_supplicant: nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0
01-01 00:02:11.266  1273  1273 D wpa_supplicant: wlan0: nl80211: Scan trigger
01-01 00:02:11.266  1273  1273 D wpa_supplicant: wlan0: Event SCAN_STARTED (47) received
01-01 00:02:11.266  1273  1273 D wpa_supplicant: wlan0: Own scan request started a scan in 0.000576 seconds
01-01 00:02:11.266  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendmsg: sock=10 sndbuf=163840 outq=448 send_len=24
01-01 00:02:11.267   540  1274 E WifiHW  : Received the following from the supplicant: <3>CTRL-EVENT-SCAN-STARTED
01-01 00:02:11.267  1273  1273 D wpa_supplicant: CTRL_IFACE monitor sent successfully to /data/misc/wifi/sockets/wpa_ctrl_540-6\x00
01-01 00:02:11.267  1273  1273 D wpa_supplicant: nl80211: Event message available
01-01 00:02:11.267  1273  1273 D wpa_supplicant: nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0
01-01 00:02:11.267  1273  1273 D wpa_supplicant: wlan0: nl80211: New scan results available
01-01 00:02:11.267  1273  1273 D wpa_supplicant: nl80211: Scan probed for SSID ''
01-01 00:02:11.268  1273  1273 D wpa_supplicant: nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 244
01-01 00:02:11.268  1273  1273 D wpa_supplicant: wlan0: Event SCAN_RESULTS (3) received
01-01 00:02:11.268  1273  1273 D wpa_supplicant: wlan0: Scan completed in 0.001481 seconds
01-01 00:02:11.268  1273  1273 D wpa_supplicant: nl80211: Associated on 2462 MHz
01-01 00:02:11.268  1273  1273 D wpa_supplicant: nl80211: Associated with 8c:be:be:3b:25:7b
01-01 00:02:11.268  1273  1273 D wpa_supplicant: nl80211: Received scan results (1 BSSes)
01-01 00:02:11.268  1273  1273 D wpa_supplicant: nl80211: Scan results indicate BSS status with 8c:be:be:3b:25:7b as associated
01-01 00:02:11.268  1273  1273 D wpa_supplicant: wlan0: BSS: Start scan result update 6
01-01 00:02:11.268  1273  1273 D wpa_supplicant: BSS: last_scan_res_used=1/32
01-01 00:02:11.269  1273  1273 D wpa_supplicant: wlan0: New scan results available (own=1 ext=0)
01-01 00:02:11.269  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendmsg: sock=10 sndbuf=163840 outq=0 send_len=24
01-01 00:02:11.269   540  1274 E WifiHW  : Received the following from the supplicant: <3>CTRL-EVENT-SCAN-RESULTS
01-01 00:02:11.269  1273  1273 D wpa_supplicant: CTRL_IFACE monitor sent successfully to /data/misc/wifi/sockets/wpa_ctrl_540-6\x00
01-01 00:02:11.269  1273  1273 D wpa_supplicant: WPS: AP[0] c4:e9:84:88:9a:e2 type=0 tries=0 last_attempt=-1 sec ago blacklist=0
01-01 00:02:11.269  1273  1273 D wpa_supplicant: WPS: AP[1] b4:75:0e:cc:50:79 type=0 tries=0 last_attempt=-1 sec ago blacklist=0
01-01 00:02:11.270  1273  1273 D wpa_supplicant: wlan0: Radio work 'scan'@0xb6bd90f0 done in 0.004528 seconds
01-01 00:02:11.270  1273  1273 D wpa_supplicant: wlan0: Selecting BSS from priority group 1
01-01 00:02:11.270  1273  1273 D wpa_supplicant: wlan0: 0: 8c:be:be:3b:25:7b ssid='Redmi' wpa_ie_len=0 rsn_ie_len=20 caps=0x431 level=77
01-01 00:02:11.270  1273  1273 D wpa_supplicant: wlan0:    selected based on RSN IE
01-01 00:02:11.270  1273  1273 D wpa_supplicant: wlan0:    selected BSS 8c:be:be:3b:25:7b ssid='Redmi'
01-01 00:02:11.272  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 BSS RANGE=0- MASK=0x29d87'
01-01 00:02:11.272  1273  1273 D wpa_supplicant: WPS: Unknown Vendor Extension (Vendor ID 9442)
01-01 00:02:11.276  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=3965
01-01 00:02:11.284  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 STATUS-NO_EVENTS'
01-01 00:02:11.285  1273  1273 D wpa_supplicant: EAPOL: EAP Session-Id not available
01-01 00:02:11.285  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=233
01-01 00:02:12.400  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:12.400  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:12.401   540   583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 42
01-01 00:02:14.881   238   533 W audio_hw_primary: out_set_parameters routing=1024, ret 0, out -1243289856
01-01 00:02:14.891   238   533 I audio_hw_primary: start_output_stream_primary... -1243289856, device 1024
01-01 00:02:14.893   238   533 W audio_hw_primary: card 1, port 0 device 0x400
01-01 00:02:14.893   238   533 W audio_hw_primary: rate 44100, channel 2 period_size 0x300
01-01 00:02:15.166   232  1291 E BufferQueueProducer: [Redmi] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:02:15.403  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:15.404  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:15.406   540   583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 40
01-01 00:02:15.663   540  1301 D NetlinkSocketObserver: NeighborEvent{elapsedMs=138500, 192.168.43.1, [8CBEBE3B257B], RTM_NEWNEIGH, NUD_STALE}
01-01 00:02:17.972   238   533 W audio_hw_primary: do_out_standby... -1243289856
01-01 00:02:18.059   238   533 W audio_hw_primary: out_set_parameters routing=1024, ret 0, out -1243289856
01-01 00:02:18.068   238   533 I audio_hw_primary: start_output_stream_primary... -1243289856, device 1024
01-01 00:02:18.069   238   533 W audio_hw_primary: card 1, port 0 device 0x400
01-01 00:02:18.069   238   533 W audio_hw_primary: rate 44100, channel 2 period_size 0x300
01-01 00:02:18.073   540   581 E WifiConfigStore: removeNetwork 0 key="Redmi"WPA_PSK config.id=0  crc=1087246119
01-01 00:02:18.079  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 REMOVE_NETWORK 0'
01-01 00:02:18.079  1273  1273 D wpa_supplicant: CTRL_IFACE: REMOVE_NETWORK id=0
01-01 00:02:18.079  1273  1273 D wpa_supplicant: wlan0: Request to deauthenticate - bssid=8c:be:be:3b:25:7b pending_bssid=00:00:00:00:00:00 reD
01-01 00:02:18.079  1273  1273 D wpa_supplicant: TDLS: Tear down peers
01-01 00:02:18.079  1273  1273 D wpa_supplicant: wpa_driver_nl80211_disconnect(reason_code=3)
01-01 00:02:18.079  1273  1273 D wpa_supplicant: wlan0: Event DEAUTH (12) received
01-01 00:02:18.079  1273  1273 D wpa_supplicant: wlan0: Deauthentication notification
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wlan0:  * reason 3 (locally generated)
01-01 00:02:18.080  1273  1273 D wpa_supplicant: Deauthentication frame IE(s) - hexdump(len=0): [NULL]
01-01 00:02:18.080  1273  1273 I wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=8c:be:be:3b:25:7b reason=3 locally_generated=1
01-01 00:02:18.080  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendmsg: sock=10 sndbuf=163840 outq=0 send_len=76
01-01 00:02:18.080  1273  1273 D wpa_supplicant: CTRL_IFACE monitor sent successfully to /data/misc/wifi/sockets/wpa_ctrl_540-6\x00
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wlan0: Auto connect disabled: do not try to re-connect
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wlan0: Ignore connection failure due to local request to disconnect
01-01 00:02:18.080  1273  1273 D wpa_supplicant: TDLS: Remove peers on disassociation
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wlan0: WPA: Clear old PMK and PTK
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wlan0: Disconnect event - remove keys
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=0x0 key_idx=0 set_tx=0 seq_len=0 key0
01-01 00:02:18.080   540  1274 E WifiHW  : Received the following from the supplicant: <3>CTRL-EVENT-DISCONNECTED bssid=8c:be:be:3b:25:7b reas1
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=0x0 key_idx=1 set_tx=0 seq_len=0 key0
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=0xb6bf50b8 key_idx=0 set_tx=0 seq_le0
01-01 00:02:18.080  1273  1273 D wpa_supplicant:    addr=8c:be:be:3b:25:7b
01-01 00:02:18.080  1273  1273 D wpa_supplicant: wlan0: State: COMPLETED -> DISCONNECTED
01-01 00:02:18.081  1273  1273 D wpa_supplicant: nl80211: Set wlan0 operstate 1->0 (DORMANT)
01-01 00:02:18.081  1273  1273 D wpa_supplicant: netlink: Operstate: ifindex=5 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
01-01 00:02:18.081  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendmsg: sock=10 sndbuf=163840 outq=0 send_len=71
01-01 00:02:18.081  1273  1273 D wpa_supplicant: CTRL_IFACE monitor sent successfully to /data/misc/wifi/sockets/wpa_ctrl_540-6\x00
01-01 00:02:18.081  1273  1273 D wpa_supplicant: EAPOL: External notification - portEnabled=0
01-01 00:02:18.081   540  1274 E WifiHW  : Received the following from the supplicant: <3>CTRL-EVENT-STATE-CHANGE id=0 state=0 BSSID=8c:be:be:i
01-01 00:02:18.081  1273  1273 D wpa_supplicant: EAPOL: SUPP_PAE entering state DISCONNECTED
01-01 00:02:18.081  1273  1273 D wpa_supplicant: EAPOL: Supplicant port status: Unauthorized
01-01 00:02:18.081  1273  1273 D wpa_supplicant: nl80211: Skip set_supp_port(unauthorized) while not associated
01-01 00:02:18.081  1273  1273 D wpa_supplicant: EAPOL: SUPP_BE entering state INITIALIZE
01-01 00:02:18.081  1273  1273 D wpa_supplicant: EAPOL: External notification - portValid=0
01-01 00:02:18.081  1273  1273 D wpa_supplicant: EAPOL: External notification - EAP success=0
01-01 00:02:18.081  1273  1273 D wpa_supplicant: wlan0: State: DISCONNECTED -> DISCONNECTED
01-01 00:02:18.081  1273  1273 D wpa_supplicant: nl80211: Set wlan0 operstate 0->0 (DORMANT)
01-01 00:02:18.081  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=3
01-01 00:02:18.081  1273  1273 D wpa_supplicant: RTM_NEWLINK: ifi_index=5 ifname=wlan0 operstate=5 linkmode=1 ifi_family=0 ifi_flags=0x11003 ()
01-01 00:02:18.082  1273  1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SAVE_CONFIG'
01-01 00:02:18.082  1273  1273 D wpa_supplicant: Writing configuration file '/data/misc/wifi/wpa_supplicant.conf.tmp'
01-01 00:02:18.090   238   533 D AudioFlinger: mixer(0xb4200000) throttle end: throttle time(8)
01-01 00:02:18.140  1273  1273 D wpa_supplicant: Configuration file '/data/misc/wifi/wpa_supplicant.conf' written successfully
01-01 00:02:18.140  1273  1273 D wpa_supplicant: CTRL_IFACE: SAVE_CONFIG - Configuration updated
01-01 00:02:18.140  1273  1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=3
01-01 00:02:18.140  1273  1273 D wpa_supplicant: RTM_NEWLINK: ifi_index=5 ifname=wlan0 wext ifi_family=0 ifi_flags=0x11003 ([UP][LOWER_UP])
01-01 00:02:18.141  1273  1273 D wpa_supplicant: nl80211: Event message available
01-01 00:02:18.141  1273  1273 D wpa_supplicant: nl80211: Drv Event 48 (NL80211_CMD_DISCONNECT) received for wlan0
--------- beginning of crash
01-01 00:02:18.141  1273  1273 F libc    : Fatal signal 11 (SIGSEGV), code 1, fault addr 0x4 in tid 1273 (wpa_supplicant)
01-01 00:02:18.145   540   581 D WifiNative-HAL: stopRssiMonitoring, cmdId 0
01-01 00:02:18.147  1063  1208 D OpenGLRenderer: endAllStagingAnimators on 0x91c92180 (RippleDrawable) with handle 0xb3b3fcf0
01-01 00:02:18.242   236   236 F DEBUG   : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
01-01 00:02:18.243   236   236 F DEBUG   : Build fingerprint: 'Freescale/sabresd_6dq/sabresd_6dq:6.0.1/2.1.0-ga-rc2/20160715:user/release-keys'
01-01 00:02:18.243   236   236 F DEBUG   : Revision: '0'
01-01 00:02:18.243   236   236 F DEBUG   : ABI: 'arm'
01-01 00:02:18.243   236   236 F DEBUG   : pid: 1273, tid: 1273, name: wpa_supplicant  >>> /system/bin/wpa_supplicant <<<
01-01 00:02:18.243   236   236 F DEBUG   : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x4
01-01 00:02:18.244   540   606 W NativeCrashListener: Couldn't find ProcessRecord for pid 1273
01-01 00:02:18.249   236   236 F DEBUG   :     r0 00000004  r1 80000000  r2 00000000  r3 00000000
01-01 00:02:18.249   236   236 E DEBUG   : AM write failed: Broken pipe
01-01 00:02:18.249   236   236 F DEBUG   :     r4 b6bcb144  r5 b6bfa280  r6 b6bcf0e0  r7 00000000
01-01 00:02:18.249   236   236 F DEBUG   :     r8 b6bcf0f8  r9 7f705a1c  sl b6bcb130  fp b6b82000
01-01 00:02:18.249   236   236 F DEBUG   :     ip b6e2ac98  sp bef23048  lr b6e227c9  pc b6e227c8  cpsr 00010030
01-01 00:02:18.286   236   236 F DEBUG   :
01-01 00:02:18.286   236   236 F DEBUG   : backtrace:
01-01 00:02:18.286   236   236 F DEBUG   :     #00 pc 0000a7c8  /system/lib/libnl.so (nla_get_u16+5)
01-01 00:02:18.287   236   236 F DEBUG   :     #01 pc 000a7ec1  /system/bin/wpa_supplicant
01-01 00:02:18.287   236   236 F DEBUG   :     #02 pc 00007b67  /system/lib/libnl.so (nl_recvmsgs+650)
01-01 00:02:18.287   236   236 F DEBUG   :     #03 pc 0009be4d  /system/bin/wpa_supplicant
01-01 00:02:18.287   236   236 F DEBUG   :     #04 pc 000152fd  /system/bin/wpa_supplicant
01-01 00:02:18.287   236   236 F DEBUG   :     #05 pc 00015967  /system/bin/wpa_supplicant
01-01 00:02:18.287   236   236 F DEBUG   :     #06 pc 00091e2b  /system/bin/wpa_supplicant
01-01 00:02:18.287   236   236 F DEBUG   :     #07 pc 0000df2d  /system/bin/wpa_supplicant
01-01 00:02:18.287   236   236 F DEBUG   :     #08 pc 00017365  /system/lib/libc.so (__libc_init+44)
01-01 00:02:18.288   236   236 F DEBUG   :     #09 pc 0000dfd8  /system/bin/wpa_supplicant
01-01 00:02:18.347   236   236 F DEBUG   :
01-01 00:02:18.347   236   236 F DEBUG   : Tombstone written to: /data/tombstones/tombstone_02
01-01 00:02:18.348   540   556 I BootReceiver: Copying /data/tombstones/tombstone_02 to DropBox (SYSTEM_TOMBSTONE)
01-01 00:02:21.149   238   533 W audio_hw_primary: do_out_standby... -1243289856
01-01 00:02:28.156   540   581 D WifiHW  : 'IFNAME=wlan0 SET ps 1' command timed out.
01-01 00:02:28.158   235   523 D CommandListener: Clearing all IP addresses on wlan0
01-01 00:02:28.158   540  1302 D DhcpClient: Clearing IP address
01-01 00:02:28.162   540  1301 D NetlinkSocketObserver: NeighborEvent{elapsedMs=151000, 192.168.43.1, [8CBEBE3B257B], RTM_DELNEIGH, NUD_STALE}
01-01 00:02:28.173   235   523 D CommandListener: Setting iface cfg
01-01 00:02:28.183   540   583 D ConnectivityService: NetworkAgentInfo [WIFI () - 100] EVENT_NETWORK_INFO_CHANGED, going from CONNECTED to DISD
01-01 00:02:28.183   540   583 D ConnectivityService: NetworkAgentInfo [WIFI () - 100] got DISCONNECTED, was satisfying 2
01-01 00:02:28.185   540   581 D IpReachabilityMonitor: clear: iface{wlan0/5}, v{4}, ntable=[]
01-01 00:02:28.186   540   581 D WifiStateMachine: WifiStateMachine: Leaving Connected state
01-01 00:02:28.186   540   581 D IpReachabilityMonitor: clear: iface{wlan0/5}, v{5}, ntable=[]
01-01 00:02:28.192   540   581 D WifiNetworkAgent: NetworkAgent: NetworkAgent channel lost
01-01 00:02:28.198   540   583 D ConnectivityService: notifyType LOST for NetworkAgentInfo [WIFI () - 100]
01-01 00:02:28.212   540  1303 D DhcpClient: Receive thread stopped
01-01 00:02:28.268   235   523 V IdletimerController: runCmd(/system/bin/ip6tables -w -t raw -D idletimer_raw_PREROUTING -i wlan0 -j IDLETIMER0
01-01 00:02:28.334   235   523 V IdletimerController: runCmd(/system/bin/ip6tables -w -t mangle -D idletimer_mangle_POSTROUTING -o wlan0 -j ID0
01-01 00:02:28.338   540   583 D CSLegacyTypeTracker: Sending DISCONNECTED broadcast for type 1 NetworkAgentInfo [WIFI () - 100] isDefaultNetwe
01-01 00:02:28.339   540   583 D ConnectivityService: sendStickyBroadcast: action=android.net.conn.CONNECTIVITY_CHANGE
01-01 00:02:28.348   540   557 D Tethering: MasterInitialState.processMessage what=3
01-01 00:02:28.496   235   523 E Netd    : netlink response contains error (No such file or directory)
01-01 00:02:28.499   540   583 E ConnectivityService: EVENT_NETWORK_INFO_CHANGED from unknown NetworkAgent
We didnot change anything in wpa supplicant,eventhough its getting crashed.
Could you please suggestion idea to fix this crash?
Raj.
Thanaraj Subramani
Labels (5)
kiwei
我也遇到同样的问题,请问这最终解决了麽
Hi Thanaraj
this can be debugged using AN4553 Using Open Source Debugging Tools for Linux on i.MX Processors
http://www.nxp.com/assets/documents/data/en/application-notes/AN4553.pdf
note, nxp has Professional Services helping to port drivers
http://www.nxp.com/support/nxp-professional-services:PROFESSIONAL-SERVICE
