I'm trying to understand how to dynamically load code with MPC5748G.
To do this I was thinking of using PIC+PID or just manage a table by myself (which will require more work).
Do you have a startup code and an example to start from?
Thanks.
I am not sure if you are interested in Position Independent Code (PIC) or Bootloader.
Position independent code for MPC5748G will be supported in S32 Design Studio v1.2, which should be released in few days.
If you need information about bootloader, please look at app note AN5319.
http://cache.nxp.com/assets/documents/data/en/application-notes/AN5319.pdf?fsrch=1&sr=1&pageNum=1
http://cache.nxp.com/assets/documents/data/en/application-notes-software/AN5319SW.zip
Martin
