ONOFF Event during the Max Timeout in IMX6UL
sadatanvashisth
What will happen if I will follow the below given sequence:
Connected switch between  ONOFF Pin and GND.
IMX6UL processor is ON
Press switch to generate a LOW Level on ONOFF pin.
Max Timeout is set  to 15Secs.
During Max Timeout I will again send a LOW to ONOFF pin from MPU.
What will be the status of "SNVS_PMIC_ON_REQ" pin.
