some ATD pins used as analog to digtal pins , other unused ATD pins can used as GPIO? I need more IO pins.
Yes, you can set some analog pins for ADC and the rest of the port as GPIO.
Please refer to the attached example code, where the I/O are set as follows:
AN0 (pot) analog input,
AN6 digital input
AN7 digital output.
