Hi all.
Currently we are flashing the PN7462 eeprom and software code using the serial wire debug interface with the LPCXpresso IDE on Windows. We'd like to automate this using a command line utility. Is there any tool available that we can use?
Hi Wouter,
You can use the LPCXpresso command line flash programming tool:
https://community.nxp.com/message/630785
Hope it helps!
Carlos Mendoza
Technical Support Engineer
