Let's assume I don't use flash as EEPROM, because flash-example fails on DEFlashPartition(), so I have to do my experiments with EEESize equal to 0.
How do I read memory at flashSSDConfig.DFlashBase ?
Already tried to read it as usual memory by address, and fail.
Examples don't cover that issue, or I might have missed it.
Thank you.
Solved! Go to Solution.
Issue resolved, "flash read" is done by accessing memory by address directly, no API functions required.
