Dear,
Now our customer MPC5606 code could work ok without the setting the STOP low power mode, but after add the STOP mode, one of their product wakeup source is RTC, another product wakeup source is CAN and GPIO, after long time run, all the two product will run crash, we could not know the status, customer need us review their low level code, including the CAN driver in bl_canFBL.c and application code in can_drv_application code.c, watchdog code in Wdg.c file, sleep setting code in RMM.C file. I attached it, thanks. They use CW2.10.
Original Attachment has been moved to: source-code.7z.zip
Solved! Go to Solution.
Hi Hanson,
I hope you don't want us to do a review of more than ten thousands lines of code. What does it mean that "after long time run, all the two product will run crash"? When? How? Is any exception triggered? Do you handle all the exceptions? Is the stack big enough?
Lukas
Hi Hanson,
Lukas
