Where is the IFC and RTC drivers for u-boot and the kernel in SDK2.0 on LS1043ardB and do you have the data sheet and part supported by the IFC driver?
Is the RTC enabled and are the Watchdog timers being used on the ls1043ard dev boatd?
Look at the Section 7.13 of the SDK 2.0-1701 documentation about RTC clock using in this BSP:
http://www.nxp.com/assets/documents/data/en/supporting-information/QORIQ-SDK-2.0-IC-REV0.pdf
See the Chapter 7.8 of this documentation about NOR Flash Device Driver User Manual.
Pavel Chubakov
