Move stack to RamAHB32
markvanderheijd
I have a problem, my local variables change value without any reason. So i think my stack and heap are overlapping each other. Is it possible to move my stack to my second ram location (RamAHB32)? On the internet i only found a way to move the stack and the heap to the second location. EnhancedManagedLinkScripts - ** Code Red Support Site ** .
I'm using the lpc1766 processor.
Thank you in advance,
lpcxpresso_supp
In LPCXpresso IDE - the simplest way to to do this would be to add the linker option:
--defsym=__user_stack_top=__top_RAM2
to MCU Linker - Miscellaneous - Other Options box in Project Properties. You can move the heap in the same way if required, as described in https://community.nxp.com/thread/389026
Alternatively, you can do this by making a minor modification to a Freemarker Linker Script : Freemarker Linker Script Templates
Note that in MCUXpresso IDE, you can do this more directly via a new entry in the Managed Linker script page of the Linker Settings. Please see the MCUXpresso IDE User Guide for more details (downloadable from the Documentation tab of http://www.nxp.com/mcuxpresso/ide
LPCXpresso Support
Carlos_Mendoza
Hi Mark,
Please take a look to the following link:
https://community.nxp.com/message/630736
Hope it helps!
Carlos Mendoza
Technical Support Engineer
