S32DS instruction
S32DS instruction
1,161件の閲覧回数
zhaoqinsu
When I open a different project file, the contents of the first project file are displayed.The colleagues next to me are exactly the same as the problems I have encountered .And sometimes open the project file, the software did not respond.I don't know the reason.Can you help me or have some S32DS instructions for us study ?Thank you very much !
タグ(1)
999件の閲覧回数
jiri_kral
you can start in the help direcotory   [your_install_path]\S32DS\help
Basically - projects in your workspace are visible on the left side (screenshot #1). You can open it by double click. Active projects are marked by arrow front of project name.
 You can create new project  from example or empty one: File ->New . If you like to add an existing project - you can import it into workspace: File -> Import (screenshot #2).
Jiri
