Need Package routing length for LS1021AXE7KQB
nileshkhupase
Can someone please help me to get Package routing length for LS1021AXE7KQB.
I need it to consider for trace routing length for PCB design.
Nilesh
Bulat
You have to consider that all internal die-to-pin wires of each interface (e.g. DDR controller) are length matched within the package. If your PCB design requires trace length matching , you need to do that between the processor's pins and pins of the target devices.
Bulat
