How to use DMA Scatter/Gather?
liujinhang
Dear All,
            I want to use  DMA Scatter/Gather function of MPC5444P,but some experiment phenomenon Confused me,the following is my DMA configurations information:
Problem phenomenon:when the major loop completed,the value of DMA_0.TCD[18].DLASTSGA.B.DLASTSGA was added to the DMA_0.TCD[18].DADDR.B.DADDR rather than  the contents of TCD_SG1[]  is loaded into the TCD register, then a DMA Destination Bus Error occurred.
 Can anyone tell me how can i do to make the contents of TCD_SG1[] be loaded into the TCD register ?
here is the reference:http://cache.nxp.com/assets/documents/data/en/application-notes/AN4765.pdf?fromsite=zh-Hans
thanks very much!
petervlna
Do you have you scatter/gather descriptor 32bytes aligned in memory?
This is mandatory.
Peter
enes
Hi, we have same problem with scatter-gather method. Can u give more details about how to solve this problem.
petervlna
Just align your TCD in memory for 32bytes. Otherwise DMA will load incomplete or incorrect TCD.
PEter
petervlna
This is mandatory.
Peter
liujinhang
It maybe the problem,The addresses of TCD_SG0[] and TCD_SG1[] are really not 32bytes aligned in memory . I misunderstood  the meaning of "0-modulo-32-byte",  thank you for your reminding!
but I do not know how to make the scatter/gather descriptor 32bytes aligned  in memory. Can you give me an example?
 thanks very much!
liujinhang
hi, Peter
I did it ,thanks for your reply.
Best Wishes
