TSI noise mode KL16
TSI noise mode KL16
alexandermaurer
like described in the Refmanual (KL16P80M48SF4RM) chapter 41.4.13.1  Automatic noise mode.
Who can explain the confusing Block Diagram Figure 41-17. What register were the counter bits taken from? and how is the combination of the Filter bits and DVolt control bits working together. The datasheet is confusing within this chapter.
Furthermore when using noise detection mode  chapter 41.4.13 the description is clear until number 10. What to do with the value of Rs and Dvolt in the end?
Thank you in advanced!
vicentegomez
with Rs and Dvolt you can select the best option of DVOLT[1:0], EXTCHRG[2:1] and EXTCHRG[0]
Please check table 43-13.
I recomend  you that you use the TSS library, instead or use only the TSI module.
regards
Vicente Gomez
alexandermaurer
Mr Salazar,
thank you for answering. Your answer doesnt help me a lot, because what you have written is already described in the datasheet.
