has anyone used CW assembly directive "PLEN" with desired result ??
klem
Print out of program listing defaults to page length of 65 lines regardless of use of directive PLEN <n>,
where n is any value. Assembly appears to accept the directive OK i.e. no error for the entry.
ZhangJennie
Hi bob.
I didn't use PLEN before but I just tested it from my side.  From my understanding, it works normal. all the code after "PLEN n" works as expect.
I don't know what version of CW you work with. I use CW5.1 for HCS12 device.
See attached video.
Jennie Zhang
Carlos_Mendoza
Hi Bob,
Could you tell us which MCU and CodeWarrior version are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
