has anyone used CW assembly directive "PLEN" with desired result ??
2,352件の閲覧回数
klem
Print out of program listing defaults to page length of 65 lines regardless of use of directive PLEN <n>,
where n is any value. Assembly appears to accept the directive OK i.e. no error for the entry.
2,112件の閲覧回数
ZhangJennie
Hi bob.
I didn't use PLEN before but I just tested it from my side.  From my understanding, it works normal. all the code after "PLEN n" works as expect.
I don't know what version of CW you work with. I use CW5.1 for HCS12 device.
See attached video.
Jennie Zhang
2,112件の閲覧回数
Carlos_Mendoza
Hi Bob,
Could you tell us which MCU and CodeWarrior version are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
