LS1021A-IOT Ethernet Switch does not work
serdaroguzata
I have an LS1021A-IOT Board (LS1021A Rev 1.0)
We use the pre-built Linux image that comes with the board.
When we connect two other devices to the switch, those devices can connect and ping each other. But neither they can ping the IOT board, not the IOT board can ping them.
The RTL8365 Ethernet switch is said to be initialized, but another thread on the forum states otherwise.
Is there a solution for this problem? What should I do to initialize the switch? Is there a code or a patch for that?
