Zipwire Driver, where is it?
gabrielebenati
Application note AN5134 mentions a Zipwire (SIPI/LFAST) driver, and the API is descripted in the same document, but where is the code?
martin_kovar
here is link to AN5134 software: http://cache.nxp.com/assets/documents/data/en/application-notes-software/AN5134SW.zip
Martin
lucabarbiero
Hi martinkovar‌,
The link is broken as of now. Could you restore it? Anyways, why can't I find AN5134SW by myself using the search feature of nxp.com? This same problem I had several times in the past with other application notes related software.
Luca
s_a_
The NXP download site is complete garbage indeed. I found the link http://www.nxp.com/assets/documents/data/en/application-notes-software/AN5134SW.zip  here: https://community.nxp.com/message/1086003
There apprently is still no driver for S32V, though, which I do not understand.
beijianfeng
Hi, I had found the community ,only found the zipwire for the MPC57xx.  Could you please offer a zipwire driver for S32V23x?  I am looking for your help ! Thank you very much!
