Hi guys,
as written above: Is MK20DX256VLK7 supported by Freescale Touch Software?
Freescale Touch Software for Kinetis MCUs|NXP
I know MK20DX256VLK7 is NOT supported by Kinetis SDK, so I don't understand if I can use Freescale Touch Software.
Thanks for reply!
Luca
Solved! Go to Solution.
Hi Luca Campanale,
About the new released library, I have install it, and check the release not, I find these information":
Supported boards and devices
TWR-K60D100M
FRDM-KL25Z
FRDM-KL26Z
FRDM-KL46Z
FRDM-KE15Z + FRDM-TOUCH
So, this new library should not support the MK20DX256VLK7, that's why I recommend you to use TSS3.1.
Wish it helps you!
If you still have question, please let me know!
Kerry
Hi Luca Campanale,
Please download this Touch sensing software:
Touch Sensing Software Suite installer Version 3.0.1
After you install it, you can find the sample code for tower K20DX72M in folder :C:\Freescale\Freescale_TSS_3_1\examples\TWRKXX_DEMO
Wish it helps you!
Kerry
Hi Kerry,
be carefull, I can use successfully TSS3.1, the library that you linked. The news is that was released another library for Touch Software: Freescale Touch Software for Kinetis MCUs|NXP on Oct. 2016, but I don't understand (cause I am newbie) if I can use it WITHOUT Kinetis SDK platform.
Please let me know. Thank you!
Hi Luca Campanale,
TWR-K60D100M
FRDM-KL25Z
FRDM-KL26Z
FRDM-KL46Z
Wish it helps you!
Kerry
