Intruder Alarm System Application Note JN-AN-1201 Not Working!
davidashraf
Contributor V
Hello dears ,
I've been trying ZigBee HA Intruder Alarm System Application Note JN-AN-1201 but it's not working.
I am sure of the connections and everything as I tried other application notes and worked properly.
Any idea about where the problem might be ?
Thanks in advance.
limcb
Have you tried uncommenting CFLAGS in the device makefiles then rebuilding ?
It looks like no debug messages are sent on a clean install.
limcb
What exactly is not working ? Which part ?
More information please.
What have you tried ? What did you expect ? What happened ?
davidashraf
Contributor V
It's not achieving the functionality described in the application note
Not even showing debug messages
limcb
davidashraf
Contributor V
It worked ..Thanks you!!
