IMX6UL 24 MHz crystal has 2.2M ohm resistor, requesting the usecase / purpose?
ramesh6663
Hi All,
     In NXP IMX6UL EVK schematic has 2.2M ohm resistor to ground. we would like to know the purpose/use case of this resistor.
please see attached snap shot from NXP EVK board
Thanks & Regards,
Rameshkumar
Yuri
 From the Hardware Development Guide :
Bias XTALI with a 2.2 M resistor to GND. Mount the resistor close to the XTALI ball.
The XTALI bias must be adjusted externally to ensure reasonable start-up time.
http://cache.nxp.com/files/32bit/doc/user_guide/IMX6ULHDG.pdf
Yuri.
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
ramesh6663
Thanks for your quick support Yuri. I will go through the document and will back if i have any queries.
Thanks & Regards,
Rameshkumar
